Question about Bosch 24 in. SHU43 Built-in Dishwasher
Smelled like burnt board
Ran washer it stop and smelled like somthing was burning. I would like to find out how to check Control board
Yes!! we had the exact same problem! I'm facing a $500 repair bill for a new clock assembly display. Which is the main computer for this model. Unfortunately, I can not find my manual to verify if this is warranty. If anyone has manual for this product please check warranty info and let me know! model#shu43c024c
  • debbiedoo Jan 15, 2008
    thank you!! thank you!! thank you!!
    Very much appreciated!!!!!
  • 146 Answers
Just so you know. Bosch has a 5 year warranty on any printed circuit board (excluding labor) so you pay only for labor charges. They have a 2 year warranty (again excluding labor) on the entire dishwasher. I am leaving a copy of my owners manuals warranty information I hope this helps.
Extended Limited Warranty: Bosch also provides these additional
limited warranties:
• 2 Year Limited Warranty: Bosch will repair or replace
any component that proves to be defective in materials or
workmanship (excludes labor charges).
• 5 Year Limited Warranty on Electronics: Bosch will repair or
replace any Bosch microprocessor or printed circuit board if it
proves to be defective in materials or workmanship (excludes
labor charges).
• 5 Year Limited Warranty on Dish Racks: Bosch will replace the
upper or lower dish rack (excluding rack components), if the rack
proves defective in materials or workmanship (excludes labor
• Lifetime Warranty against Stainless Steel Rust Through:
Bosch will replace your dishwasher with the same model or
a current model that is substantially equivalent or better in
functionality, if the inner liner should rust through (excludes
labor charges). Bosch will replace the stainless steel door if the
door should rust through (excludes labor charges).
The foregoing timeline begins to run upon the date of purchase, and
shall not be stalled, tolled, extended, or suspended, for any reason
Repair/Replace as Your Exclusive Remedy: During this warranty
Posted on Jan 15, 2008
Lg dishwasher smells like something is burning
This is an interesting problem and it requires some testing equipment to see what the problem is. You have to check the heating coil if it is a washer that heats the water. You also need to check the control board and some other things to see if you can locate the source of the burining smell. To perform these checks requite some test equipment like a meter.
May 22, 2013 | Dishwashers
My boilder is struck by lightning and had burned plastic smell. then it stopped working. The power line seems to be fine, somewhere inside got struck. Any way this can be fixed?
You can change out all the heating elements and controls, but hard to say what lighning did without seeing and being there. Sounds like the control board got burnt and that was the smell you smelled, but I can't promise the element is good.
Jul 10, 2011 | Zojirushi CDWBC40 Micom 4Liter Electric...
Kenmore washing machine ultra fabric care model #92282800. Stop woking suddenly and smell like burned.
Thanks for choosing FixYa and welcome. You need to check the control panel. There is a good chance you can visually see some damage since you smelled the burnt smell. Check your belt(s) as well. Check to make sure the motor is running. Something inside may have burned up. If you have no power, check these below.
May 12, 2011 | Washing Machines
The washer was in spinning cycle, when I smelled plastic burning, then it stop all together. I was able to turn it off, but now it doesn't do anything. What could this be?
It will be good to start with looking into the washer with the power switched off smelling for the source that burnt. this will be easy to find and the possible area could be the power section in the main board- the control board.
Once you have isolated the burnt component we can decide if the part alone can be changed or the full board needs a change.
The motor and the drain pump also must be checked for any burnt outs.
Dec 02, 2010 | GE WSXH208A Front Load Washer
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
No power to control board
yes, i'm afraid you have a burnt resistor on the control board, ( you can't just replace the resistor) you must replace the board. sorry not cheap.
Mar 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Smelled like burning plastic
Ron, is this a dishwasher or clothes washer? If a dishwasher, check the wire nuts in the junction box. If there isn't a melted wire nut from a loose connection. Then you have to pull the outer door panel, then you can pull the control panel assy. This will require a t20 torx bit.
Jan 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
reove screws holding on outer panel and unplug all the leads ( they are all coded so you cannot cross them ) open up plastic cover on module to reveal circuit boeard
Bosch 24 in. SHU43 Built-in Dishwasher Logo
382 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
