Question about JVC JY-HD10U Mini DV Digital Camcorder
Broken power button
Button or knob to power up my jvc jy-hd10 just fell off i can see how a small copper piece behind the button looked worn and just cracked. My question is how and where do i go to replace this?
  • Anonymous Oct 15, 2008
    I contacted JVC and they said I needed to send it to one of their repair centers. Not sure if the camera is even worth that trouble any longer???
2 Suggested Answers
emissionwiz
  • 82208 Answers
SOURCE: JVC GR-HD1U power button fell off, where can I get it replaced?
You will need to send it in for repair, no outside repair facility can do this type of repair locally. JVC will most likely offer an exchange and not repair the one you now have.
Posted on Sep 22, 2016
Power button broke gfdn240el1ww
There are two main pieces to the front panel for the GFDN240EL1WW dryer-- the plastic panel and the circuit board. The actual replacement part is: Control Panel WE19M1687. The panel can be purchased for from places like partselect.com or repairclinic.com or Amazon or even EBay, etc. for $100-$200+.
The power button is just a piece of plastic mounted to another piece of plastic; it is not electronic. When pushed, it presses against the circuit board, which then turns the unit on/off. When the power button breaks, it typically means the little plastic button has broken off from the plastic panel. Most likely, the problem is the mount point for the button and the button is actually re-usable.
A cheaper quick-fix is to:
  • Remove top screw from back of the front panel
  • Remove main front knob from the panel
  • Remove screw from behind the front knob
  • Grab both sides of the front panel and push/pull up to remove the panel
  • Disconnect the block connector (power) from the circuit board after removing the panel
  • Locate the power button and mounting position
  • Inspect to see if it looks like you can glue the button back into place
  • Buy a small tube of loctite Stik'n Seal Ultra Universal Adhesive
  • Put some Stik'n Seal on the button mounting point for the power button (be generous)
  • Press the button onto the mounting point and hold for a few minutes
  • Add more Stik'n Seal around the edges of the mounting point and the button mount after you have held the button in place long enough so that it sticks
  • Let the whole thing dry for several hours (instructions on the adhesive say 24hrs
  • If you are worried about the button staying seated while the adhesive sets, you can always try tape it into place
  • When dry, replace the front panel by reversing the steps above used to remove the panel: connect the power block, slide the panel back into place, replace the front screw and knob, replace the top screw in the back of the panel
Jan 23, 2013 | GE DBVH512GFWW Dryer
Trying to remove light and washer wiper knobs from 1001 Ford F150.
Headlight knobs are attached to a long stem into rueastat switch (dash light dimmer ) push the small button spring loaded of headlight switch behind dash panel. Knob with stem will come out. Careful not to turn on headlights & run battery dead.
Wiper knob has a release tang behind knob push up tang with a small screw driver ( pocket type flat ) or look for a small set screw on knob
Speedometer cable may be broken,loose from dashboard connection,loose from transmission or broken cable gear in trans. Not sure when ford swicthed to magnetic sensors. Possible lost pick up sensor on drive shaft
Mar 08, 2012 | 1991 Ford F150
We changed the battery but a small red piece of plastic fell out. It goes behind the plug-in port somehow but after much effort, we haven't been able to put it together so we can sucessfully charge it up...
The red piece is the voltage switch. It goes at the bottom of the shaver and the rectangular part will correspond to the rectangular cutout at the bottom. The copper contacts will go against the circuit board
Jul 01, 2017 | Norelco 3605 X Electric Shaver
Timer shows F30
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Nov 04, 2010 | Kenmore Ovens
The battery eject button is broken and if any pressure is placed on the battery during recording, it will pop off and then the data needs to be repaired after hooking up to AC power. Out of warranty - not...
A picture of the broken area would help but if you are mechanically gifted you could make one but if you have the pieces, you may be able to weld them together with the likes of solder wick and melting the wick (very small copper braid) into the plastic with a small soldering iron. In either case you will have to partly dismantal the case to remove and reasemble the brocken button. You have to hold the braid in place with a knife blad or small pliers while it is cooling. There is some skill involved. Glue the plastic first if it helps to hold it together before melting the wick into it. Nail polish help to prevent oxidation of the copper.
Norm
Jan 04, 2010 | Hitachi DZBX35A DVD Camcorder
Latch button will not release door on Sharp R-5H84 microwave . Push button and can pull the door open with a slight amount of force.
Sounds like a portion of the release knob is worn or broken, or a metal piece behind it is bent.
Jul 26, 2009 | Microwave Ovens
Broken Optical Fibre?
CCD Failure/Lens Cap Warning Error
JVC
has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty. Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on
30th June 2008 and is applicable only to failure of the CCD image sensor.This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
Oct 18, 2007 | JVC GR-D70EK Mini DV Digital Camcorder
Tripped out
take off the oven knob, behind is a piece of plastic - the reset switch is behind that.
you have to poke a smal screwdriver in and should hear a small click
Sep 02, 2007 | Electrolux EOG7330WN Gas Double Oven
JVC JY-HD10U Mini DV Digital Camcorder Logo
56 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
