Kirby Generation 3 Bagged Upright Vacuum Logo
Posted on Nov 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to remove the top of the motor unit on a Kirby Generation 3 to access the motor area of the vacuum
vacwater
Level 2:
  • Expert 175 Answers
  • Posted on Nov 28, 2009
vacwater
Expert
Level 2:
Answers
175
Questions
0
Helped
132732
Points
383
First remove the back, then remove the handle assembly. Then pop off the plastic switch cover and it has one screw on the back you will need to take out, then there are two screws in the front of the body housing and two on the back that you will need to take out and then you are ready to take the top cover off and get into the motor area.
4helpful
I need to replace power supply. where the cord
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
2helpful
2answers
We have a kirby generation 3 and it slows down and speeds up almost sounds like it is going do quit could this be a brush problem in the motor sometimes it will quit.
You may need to service you Kirby. Go this page HERE, fill out Service Request Form and ship to us together with you Kirby. We will inspect it and will call you with an estimate.
Good Luck,
Rocky
My kirby generation 3 wont come on
Make sure cord is not damaged. Check to see nothing is blocking hose or carpet nozzle(where beater brush is or brush roll). Plug unit in to a receptacle that you know has power going to it. (Lamp you know works when plugged into same. Using hose on front, make sure bag bottom completely attached to exhaust, the hose has a little arm like thing that will depress the safety switch on the front of the unit, and turn on using foot switch at the back of the unit. If these do not work, it could be one of two safety switches, dirt may have fouled or switch may need to be replaced. Authorized Kirby Dealer in your area: Replacement parts, Kirby Distributor, call: 1-800-437-7170 United States and Canada
2helpful
1helpful
Motor problem
First six pictures HERE will let you know how to remove shell to see the motor. I would not recommend starting it before you get the screw out (you will need to remove 5 more screws from the front f the unit to get the fan case off). The fan case is glued so you may need to use screw driver and pray the fan case of the unit. If fan is damaged - remove it from Kirby as damaged fan is out of balance and Kirby will vibrate like crazy. Shaft has opposite thread so you have to turn it CLOCKWISE.
If the fan does not come off easily you may have to remove this part and access the rear of the motor where you can use a wrench to hold the armature (you will see where you can hold it right behind the commutator. Removing slide bracket assembly memorize where the wires are plugged in and how it is engaged with the transmission.
God Luck
Rocky
Replace the roller on my kirby vacumm generation 3
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=814340
Generic problem for all Vacuums
Posted by tlourene on Jul 21, 2008
Replace the roller on my Kirby Vacuum Generation 3
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to replace the brushroll on the Kirby G3 you need to dial off the belt and then release the lever to remove the bell housing, then there are 2 levers that you need to open then you can get @ the brushroll --- take out the brushroll and replace the brushroll and a new belt – make sure you change the belt every 4 to 6 months for the best cleaning. Make sure when you put the new belt in the housing that the screw heads are facing down – then you can replace the bottom plate, dial the belt on to the belt pulley and replace the bell housing. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 21, 2008 • Vacuums
2answers
Kirby
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11560&thid=798201
Kirby
Posted by ronholliehaw on July 17, 2008
Hello, I have a Generation 3 Kirby- it was working - I turned it off & it will not turn on again - is there a safety switch /reset button or did the on/off switch go out - I have had it 15 years & replaced the switch 1 time - Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The chances are it is the safety switch 1st and the foot switch 2nd. The safety switch is in the front of the fan housing of witch the bell housing hooks into. Both are about the same price plus labor. So feel free to do it yourself or to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
1-800-494-8586
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Kirby generation 3 fan
You have to take off the top cover, then the handle pivot. Look down at the back of the armature you will see that it has a flat spot, you use a small vise grips or pliers to hold it, turn the belt pulley to the right if I remember right and turn the pulley off. If it won't come free, use a couple of flat blade screwdrivers and pry up to pop the fan off. Then put it all back together.
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
