Question about Toshiba W522 VHS VCR
Tracking display will not go away
Mine is actually a W512 VHS VCR. Cannot make the tracking display disappear. The display button used to work. The tracking button next to it will change the tracking mode. How can I make the display disappear from screen.
  • 146 Answers
Try unplugging the unit for 30 minutes and see if that takes care of it. Just turning it off won't clear it because as long as power is coming to it ex. plugged in, it won't clear. If that doesn't take care of it you may have a problem with the selector board. If so get yourself a new VCR as it will cost more than it is worth to fix it.
Posted on Jan 15, 2008
Usually VCRs do not offer specifically labelled tracking buttons as such, however they may incorporate tracking into their channel UP/DOWN buttons, both on the front of the main unit and/or remote. Some brands also offer V-LOCK (vertical lock or still image adjustment) (in pause mode during playback) to stabilise the image, reducing vertical jitter, which again can be adjusted as required using the same buttons as used for tracking. In most cases, pressing both CH UP and CH DOWN together while the tape is playing should centre track (revert back to auto tracking) the unit.
I am sure if your VCR has channel buttons on it, try pressing either one while a tape is playing. See if it affects the tracking at all. If it does, press both buttons together for 5 seconds or so, then release - auto/centre tracking takes over.
It costs nothing to try this, and it won't hurt your machine or your tapes.
Apr 20, 2011 | Toshiba W522 VHS VCR
Samsung VCR SV-5000W Tracking Problem Symptom: I've used Maxell VCR Head Cleaner VP-100. Still having small white streaks across screen. I can apply small amount of pressure to bottom or top of VCR deck...
Your chassis ground is intermittant. Remove the VCR cover and look just behind the head drum. You will see two copper tangs sticking out, these supply the ground to the grey chassis and are a pressure fit. Remove the 7 screws from the grey chassis, two are underneath the VCR, two on top near the VHS tape opening, and three larger screws are on top of the chassis (2 near back and 1 near front). This will allow you to lift the grey chassis about a 1/2" and you can then reach below the copper tangs and gently pry them up. Reinstall the 7 screws and the VCR cover and the snow will disappear.
Nov 26, 2010 | Samsung SV5000W VHS VCR
I have a JVC HR-J610U VHS VCR cannot set tracking
On the VCR its self hold in the + and - buttons to set the tracking manually.
Mar 15, 2009 | JVC Televison & Video
Vcr player
On most VCR's you can use the channel buttons to adjust the tracking. There's usually channel buttons on the front panel of the machine so you don't need a remote.
Jan 17, 2009 | Optical Coating Model 108 VHS VCR
DVD-V3500 DVD player works fine the VHS does not display
Its problem of dirty / clogged video heads and can be solve by using VHS video head cleaning cassette.
Sep 14, 2008 | Samsung DVD-V3500 DVD Player/VCR
Counter display will not go away
The time-honored classic solution is a piece of black electrical tape!
Actually, try reseting the display processor by either unplugging it or some VCR's have a little tiny hole somewhere you put something like a toothpick into to push a button.
Jan 15, 2008 | Toshiba W512 VHS VCR
VHS tracking
The tracking control is on the remote or you can try the channel up & down on the remote.
Dec 19, 2007 | RCA VR637HF VHS VCR
Vhs playback problem
either extremely dirty heads or there is a tv/vcr button that needs to be toggled. Most have auto tracking, old ones have a knob or 2 buttons under a panel somewhere for tracking.
Dec 02, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Jumping screen on sylvania 6240ve
Press the Channel up & down buttons at the same time and on most VCRs this deactivates auto tracking option. then press the up or down channel button to adjust tracking.You might try this first. pressing them both at same time reactvates auto tracking. This might not solve the problem but at least you eliminated one possibility.
Nov 12, 2006 | Sylvania 6240VE VHS/S-VHS playback VCR
Toshiba W522 VHS VCR Logo
219 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
