Question about Dell 3100cn Laser Printer
Paper Jam Errors
I am getting the message "Paper Jam Reg1" and "Open Reg Cover". Just before this happened, four sheets fed at once and all caught in Reg1. I was able to remove them intact although it took quite a pull. I am using the letter tray for cardstock, and I normally get away with it, if I am willing to put up with having a false jam signal after nearly every sheet. I can't use the MFU because it is totally hosed and makes a very loud racket if I send something through it.
My theory is that when the four sheets of paper jammed in Reg1, it tripped certain sensors that didn't reset or were damaged.
I have tried power off/wait a few minutes/power on, but it didn't solve the problem.
  • 1 more comment
  • smak90 Jan 25, 2008
    I have exact same problem. My wife loaded a peice of cardboard at the bottom of a stack of photo paper. It jamed it and she pulled it very forcefully to remove.
  • ciaobaby Mar 05, 2008
    I am getting the message "paper jam; open reg cover". I cannot see any evidence of a paper jam. Please help!
  • bugmenot2 Mar 25, 2009
    I've got this problem when I pulled out some stuck card stock. A plastic piece broke off for me though. Must be what hits the microswitch. It's a rod about 3" long. On one end is a hook about an inch long, and on the other end is what I'll try to describe as a segment of a circle 1" long, by about 3/8" wide . Too bad I can't post a photo. Got the thing partially apart, but haven't found where this goes yet.
Switch off power to printer and switch on again, worked for me
Posted on Jul 31, 2009
I had this and tried the following, I emptied the paper drawer and MPF tray and then remove the paper drawer from the printer, there are little latches on the upper inside of the paper drawer. thenmade sure there was no debris, and re-installed the paper drawer and the problem went away
Posted on Feb 02, 2008
Paper jam
  • Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  • 2Turn off the copy machine before pulling out the paper.
  • 3Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  • 4Check for any paper fragments and clean up any torn pieces.
  • 5Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  • 6Replace the cover and paper tray and turn the machine back on.
  • 7Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push
    see the diagram for copiers and let`s the way of paper for troubleshooting .
  • 12_19_2011_4_33_16_pm.jpgsincerely. Merry Christmas.
    ernesto cuadra
    managua, nicaragua. c.a
    Dec 19, 2011 | Office Equipment & Supplies
    Paper Jam in Duplex mode when printing more than 1 sheet
    check between the rollers there will be small bits of paper jammed in that is the reason.
    Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
    Tip
    How to Fix a Paper Jam in a Copy Machine
    It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
    1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
    2. Step 2 Turn off the copy machine before pulling out the paper.
    3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
    4. Step 4 Check for any paper fragments and clean up any torn pieces.
    5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
    6. Step 6 Replace the cover and paper tray and turn the machine back on.
    7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
    on Jul 14, 2010 | Office Equipment & Supplies
    After a paper jam, the printer LCD come up the back cover is open.i have secured it tightly. and clean up in side. but nothing is happening.
    When you turn the printer off and back on again with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
    Jan 12, 2011 | Brother MFC 7420 All-In-One Laser Printer
    Back cover open close the back cover
    If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
    Dec 03, 2010 | Brother MFC-7820N Printer
    Close the back cover, the back cover open
    If you turn the printer off and back on again with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
    Nov 25, 2010 | Brother MFC 7420 All-In-One Laser Printer
    While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
    Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
    Oct 24, 2009 | OKI C5500n Printer
    Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
    Hope this helps....
    Explanation of the paper jam message
    A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
    NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
    Clearing the jam
    To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
    Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
    NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
    For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
    NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
    Remove any jammed sheets of paper you find and try printing again.
    Dec 12, 2008 | Lexmark T640 Laser Printer
    Close reg cover
    After researching the error online, I solved my problem by simply pushing the back cover of the unit closed; I didn't even know it had come open after I removed my jam.
    Hope this helps!
    http://support.dell.com/support/edocs/systems/3100cn/en/UG/section20.html#638412
    Jul 18, 2008 | Dell 3100cn Laser Printer
    Paper jam error message
    I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery with age, and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
    The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it). And then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
    Dec 28, 2007 | Canon PIXMA iP1600 Printer
    Dell 3100cn Laser Printer Logo
    996 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
