Question about Maytag 24 in. MDB8951AWS Stainless Steel Built-in Dishwasher
Load crunching noise
18 mos old. Dishwasher started quietly and then started extremely loud crunching sound. Repair guy tells us that it's the motor. Anybody else have this problem?
    Scholar:
  • 146 Answers
The motor has a 2 to 5 year warranty so if that's what the repair guy says I would go ahead and have it repaired. The noise can come from the pump, impellers or the motor. But if he's sure that's where it's coming from have it fixed by the repair service under warranty.
Posted on Jan 15, 2008
My ge whdsr 316G washer is extremely noisy when agitating
Most likely your transmission is about to fail, Run it into the ground if you can stand the noise. Prepare for transmission replacement.
Online applaince parts are usually very helpful. Parts probably $200. plus. If you are tool literate, you may be able to do it. If not I don't recommend. You might want to consider a lightly used replacement, or New.
Jul 07, 2012 | General Electric WHDSR316G Top Load Washer
Whirlpool quiet partner 1 is suddenly loud
Dear Sir : please see the diagram attached.
May 08, 2012 | Whirlpool Dishwashers
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    It runs EXTREMELY loud
    Hello, W/D here.
    The problem is most likely in the motor/pump assembly, and they're sold as a unit. Prices range from about $130 to $220 or so. You can look up your model on this site for comparison shopping, if you decide to look somewhere else.
    http://www.appliancepartspros.com/Appliance-Parts/Dishwasher-Parts/Dishwasher-Pump-Motor-Assembly/index.aspx
    If you are handy with tools, this is a job that is intricate, but doable. I have made a similar replacement on a KitchenAid dishwasher, where the noise started out low and increased over a period of several months to sound, as you said, EXTREMELY LOUD. Six months later, the noise started again, and increased again. I changed out the machine after that.
    It might be worthwhile to get a local tech to give it a listen, and a free estimate, and decide whether to repair or replace it.
    Best regards, --W/D--
    Mar 17, 2011 | KitchenAid Dishwashers
    My whirlpool dishwasher is supposed to be really quiet, and it was for about 2 years, the past 6 mos it is really, really loud. What happened? Does it need a new motor?
    Hi, You don't necessarily need a motor, a couple of things could be to blame. It may be debris in the sump well or the chopper assemblies on those can become worn and break loose from the motor. Either of these things can certainly make your normally quiet dishwasher very loud. If you feel capable pull the sump cover off and inspecf it ( youtube has great "how to" video's ) or if you don't feel comfortable doing this, it may justify paying a service person to check, but I wouldn't be too quick to right it off. Hope this was helpful. Thank you for visiting "fixya" and good luck moving forward. Macmarkus :)
    Mar 15, 2010 | Whirlpool GU2200XTSS Built-in Dishwasher
    Kitchenaid Whisper Quiet + dishwasher making loud humming noise
    Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
    Jul 14, 2009 | KitchenAid Dishwashers
    Kitchenaid dishwasher makes a crunching sound during rinse cycle
    Sounds like a bearing in the pump is going. This would cause a leak be careful leak will get worst.
    Sep 18, 2017 | KitchenAid 24 in. KUDS02FRSS Stainless...
    1 week after installation- is very loud
    dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
    Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
    Maytag 24 in. MDB8951AWS Stainless Steel Built-in Dishwasher Logo
    208 people viewed this question
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
