Question about Jazz JDC31 Digital Camera
Batteries Every time i put new batteries in my camera it say that the batterie voltage i low when the batteries are brand new. I only had the camera for 3 weeks now and now its doing this what wrong with it?
  • 22 Answers
This happens with almost all digital cameras. You have a couple options. first you can buy lithium batteries, which are a little more expensive but last considerably longer in digital cameras.
The second is you can buy rechargeable batteries, which in my opinion is the best option because you can reuse them, and they also last really long in digital cameras.
the problem is, you just cant really put normal batteries in digital cameras. Lame but true
I hope that my answer was of help!
Posted on Jan 15, 2008
Put in new batteries. It will turn on and then stay on for about 1 second and then goes black. Help. I have the kodak easy share c183
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to Ni-MH or alkaline batteries.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
May 23, 2014 | Cameras
Tip
Low Power Warning For Full Charged Camera Battieres
<span> <p>I have noticed that, some users asked that, there old cameras always display low power warning for full charged new batteries, or there will be a low power warning after only taking 5-6 pictures.<br /> <p>If you have met this question (I wish not), I'd like to share the solutions.<br /> <p><span> <p>The this problem are so common for <a href="http://www.digital-camera-batteries.net/canon.htm">Canon PowerShot</a> A series cameras when you try to powered your camera by Ni-MH batteries. This is because that, the camera judge the battery is power off by voltage of the battery. And if you use Ni-MH batteries for your camera, the Ni-MH batteries' voltage is lower than the Li-ion ones and close to the camera's judge voltage of low power, so the camera will warn you to change a new battery.<br /> <p>So if you use <a href="http://www.digital-camera-batteries.net">Li-ion camera batteries</a> this questions will be solved simply.<br /> <p>From <a href="http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/">http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/</a><br /></span><br /></span>
on Apr 26, 2011 | Cameras
Just purchased lithium batteries and indicator showing low battery
Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Jan 09, 2014 | Samsung S860 Digital Cameras. 8-megapixel...
Won't turn on
Did you check if the batteries are inserted correct? + to + and - to -
Also it could be you have the wrong batteries.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to Ni-MH or alkaline batteries. Checking the voltage of every cell with a multimeter could tell you for sure the batteries are good. Voltage should be jus above the voltage printed on the battery when measured.
Never use manganese (Zinc-Carbon) batteries, because they don't have enough capacity to let a camera work correct.
Jan 01, 2014 | Vivitar ViviCam 5022 Digital Camera
I have a Canon powershot A1100is dig camera. When I try to turn it on, it reads need new batteries. even if I change the batteries. Sometimes it wont even turn on. Help
Do you using Ni-MH batteries? Canon cameras judge the battery is low power by the real-time voltage of the batteries. And the voltage of Ni-MH batteries are lower than Li-ion ones, so the camera will notice low power even there are new batteries. Try Li-ion ones and see is anything help. best wishes!!
If you will use of a special battery, please come to our online shop for digital camera batteries
Feb 21, 2011 | Canon PowerShot A1100 IS Digital Camera
Whenever I put new batteries into my Canon Powershot A480, I get the same thing - I get the 'Low Battery' red flashing light. And Then as I go to take a picture it shuts off and says ; Change The Batties....
I've got the same problem with 2 A 480 canon. I put in NiMH batteries and they work fine. If you put in slightly drained used batteries they work!! Nimh batteries are 1.2 volts and Alkaline are 1.5 volts. There is definitly a problem with this camera. I measured the voltages of brand new batteries 1.51 volts each and they didn't work. I put in some old batteries 1.4 and 1.42 volts and they worked fine.
Dec 17, 2010 | Canon PowerShot A480 Digital Camera
Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Jun 18, 2009 | Samsung Digimax D53 Digital Camera
Low Battery
Many Kodak brand cameras have this problem, and when I say many I mean almost all. The only solution is to try different types/brands of batteries until you find one that lasts.
Jan 17, 2009 | Kodak EasyShare C875 Digital Camera
Battery low all the time
Try Eneloop batteries from Sanyo. They have the higher voltage needed. AND that voltage doesn't sag under the initial startup load.
Nov 02, 2007 | Cameras
Battery Problems
I had problem with the "brand new" battereis that came with camera (date on batteries was thru 2014) ... after 2 or 3 pictures ... camera would not work. I replaced with fresh batteries ... works great now. I checked voltage on shipped batteries (that came with camera) ... was about 1.3 volts ... new battereis should be 1.55+ volts. This suggests that shipped "brand new| batteries ... are not "brand new". I called Polaroid .. best I got was "sorry" ... and "call Duracell".
Sep 04, 2007 | Polaroid I533P Digital Camera
Jazz JDC31 Digital Camera Logo
Top Jazz Cameras Experts
wgenglan
Level 1 Expert
pontelemon
pontelemon
Are you a Jazz Camera Expert? Answer questions, earn points and help others
