Question about Brother IntelliFax-2820 Laser Fax
Brother intellifax 4100
How can I reset the change drum unit soon display if I just refilled the empty toner and installed a new drum and blade on same cartridge?
any help is good. tanx.
  • Drum problme Jun 04, 2008
    Yes we have the same problem.
    Just changed the toner and replaced the drum and still get the message "change drum soon"!!
  • Anonymous Jun 24, 2008
    We just replaced the toner and drum and it still shows the message to change drum soon....I know there's a combination of keys to push to cancel this message , but I cannot locate it. It isn't the clear button and the 1 button..
Open front cover, press "clear" and 1, that will clear the change drum soon error
Posted on Jun 16, 2008
  • ubuibme_1970 Dec 07, 2010
    Open front cover, press "options", Replace Drum? shows on LCD, press 1 to change drum.
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Brother intellifax 4100 e display says to replace toner but cartridge is not empty. Is there a reset for the toner?
There is no reset for the toner. It uses an optical system where light shines through the toner. Shake the cartridge gently left to right to even out the toner and try again.
Jul 01, 2011 | Brother IntelliFax-4100e Fax
Our fax machine starting displaying a message that said change drum soon...therefore i changed the drumand the toner itself but the message is still popping up.
Get out the operators book it will walk u through the steps on how to reset drum. Machine will still work ok with out resetting the drum counter.
Aug 13, 2010 | Brother IntelliFAX 4100 Laser Fax
Toner on paper edges
The cleaning blade inside of the drum unit is worn out. Replace the Drum Unit
May 19, 2010 | Brother IntelliFAX 4100 Laser Fax
Open the door where the toner cartridge is, and push the clear key and look at the display where it will say reset no press 1 yes press 2. That should do it.
Feb 23, 2010 | Brother IntelliFAX 4100 Laser Fax
How do you change the drum on a Brother IntelliFAX 2920?
Open the front cover.Pull out the drum and cartridge unit.Unlock the toner from the drum with the blue clip.Take the new drum remove all the pacaging material insert the toner in the new drum.Replace the drum and toner unit back in the machine.While the cover is open,press the clear button.The machine will display "Replace drum yes or no" Select Yes.Close the front cover.
Dec 07, 2009 | Brother IntelliFax-2920 Fax
How do i reset the message change drum soon on
Press Clear.
8 Press 1 and when the LCD shows ACCEPTED,
and then close the front cover.
Jun 05, 2009 | Brother IntelliFAX 4100 Laser Fax
Change drum soon
Instructions are in the box that the new drum comes in.
Jan 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Error 7C
There's no manual for "machine error 7C" in Bro IntelliFax 4100. To fix this issue. You will need to pull out the toner. Note: the toner and drum are connected.....At the left corner of the drum. You will see a blue tab......You will need to slide the blue tab back and forth for 20th times....And put the toner back in its place.....This is just a temp fix but you need to replace the drum to have it working its fullest......
Dec 24, 2008 | Brother IntelliFAX 4100 Laser Fax
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
IntelliFAX 4750 Toner Empty
Hi, have you changed the drum anytime soon? If so did you clear the message before installing the new drum? The only other option would be to try a diffrent toner. There is not toner reset counter like there is for the drum! So I would reset the drum counter and see what happens. Good Luck
Nov 08, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFax-2820 Laser Fax Logo
1,584 people viewed this question
James Cagle
James Cagle
Jim Keysor
