Question about Samsung SGH-D600 Cellular Phone
Won't start on full battery
I pressed the end call button to end the call and it didn't work so I had to take out the battery to end the call. Now my phone wouldn't turn back on. Can anyone help?
  • 83 Answers
Take ur batt out 4 30secs then put it bk in then try turn it on shoud work
Posted on Jan 17, 2008
Console lights up but when I press any of the buttons it won't start
I am having same problem. The console lights up but none of the button works, including TV and the fan.
I actually took everything apart, unplugged and re-plugged the connectors on the PCBs of both side of the console, it still didn't help. Looking at the electronic configuration, TV, fan, left and right panels are relatively independent. I believe the driver/motor module is still working, the most likely cause of this is the controller CPU.
Jun 05, 2012 | Reebok Vista Treadmill - RBTL13305
My Canon powershot SD1000 screen isn't working. Iv'e charged the battery but when I turn the camera on, the screent is black. It won't take any pictures
It's very likely the CCD sensor that needs to be replaced. If you need to have it serviced, this place is excellent for the Powershots and not much at all if you need to have one fixed:
Before having it fixed, press the DISP button first and make sure you just didn't turn the display off. If you end up needing service for the Canon, that place above is really great for these cameras.
Apr 15, 2012 | Canon PowerShot SD1000 Digital Camera
Wont turn on
Please unplug the battery (remember to disconnect the charger),
then, hold on the power button for a minute,
after that, connect the charger, and try to power on the laptop.
If it didn't work, you need to visit the technician
If it worked, disconnect the charger and connect the battery
If it worked, things are going well.
If not, the battery have problem.
Please tell us the results
Nov 12, 2011 | Sony VAIO VGN-FJ270/B Notebook
Remote wii not working
First check your batteries level and if is nothing covering the sensor bar... Next press 1 and 2 button simultaneously.
If still didn't work press red connection button at back of wii remote near the batteries e press the same button on wii console.
Oct 10, 2011 | Nintendo Wii Console
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
I connect the charger of my htc hero. at first it was charging. after an hour i noticed that it stopped from charging. when i turned on my phone it didn,t open.
Open the back cover , take the battery out . Press and hold the power button without the battery . Put the battery back in . Try to power it on .
If that doesnt work try below steps , ( note : you will loose your data )
Power the device OFF. Press and hold the HOME and Back Arrow buttons. While holding these buttons, press the End Call button once. Release the Home and Back Arrow buttons and press the Trackball to execute the Hard Reset. The device will reboot once the process is complete.
Thumps for my solution if it works .
Aug 15, 2011 | HTC Hero Smartphone
My remote won't set to the tv I tried pressing the set button and it didn't work then I replaced the batteries to see if that would work but it didn't and now I don't know what to do please...
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
Jul 21, 2011 | Vizio VF552XVT 55 in. LCD HDTV
Hi..i have acer aspire one ZG5. at my place renovation work was going on. I didn start it for atleast 1 month. When i pressed the ON button....nothing appears on Screen, no sound from mother board. Some...
Use a vacuum cleaner and **** out the dust from every where.remove battery, clean the contacts and replug it. check the adapter cord,make sure that third point (neutral) is connected to the socket. and plug it. Press and hold power button and it should work.
Sep 04, 2010 | Computers & Internet
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Samsung SGH-D600 Cellular Phone Logo
128 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
