Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Dryer letting in Hot water
Hi, please can some one advise me if they have a solution. Recently my dryer has started letting in hot water i think during the drying cycle on my WD63. I was thinking about maybe trying to detach the pump in the back to take a look but have never attempted this.
What do you think the problem is?
Many Thanks
    Scholar:
  • 90 Answers
Have made suggestion on later note.
Posted on Feb 10, 2008
New dryer running on high heat. I was doing dishes using hot water & noticed the dryer stopped. Its fuse had tripped. Once I fixed that, I let the dryer complete the cycle without using hot water.
if you start the dryer with nothing else running and it doesn't pop the fuse then it's not the dryer,if it was the dryer the fuse would pop no matter what,i would call an electrician in to check the fuse box,if you start each appliance by themselves and it doesn't trip the fuse then it has nothing to do with any of the appliances or the fuse would trip if there was a problem,somehow the way your box is wired the appliances are somehow connected and the fuse is popping,i would start with an electrician,somehow it's drawing over what the fuse can handle only with the dryer and one of the other appliances running,i have old wiring in my house,i was putting in a new fan light,i took the fuse out and still got popped even though the light and fan wouldn't work,whoever worked on the wiring jumped power from another room and i had to remove both fuses to finally kill the power,you might have the same thing going on,that's an electric dryer so it uses 240 volts,someone might of tapped off of another power source in the house to get the other leg or 120 volts so the hot water tank and dryer could be connected even though they have their own fuse,i guess you could remove the hot water tank fuse and start the dryer and see what happens,it might not start or if it starts you might have no heat in the dryer because like i said it has 240 volts going to it but it sounds like they are somehow wired together.hope this helps.
Dec 28, 2017 | Dryers
My dryer is way too hot, besides fading and ruining the clothes, it also blows out the electrical switch. I have to run outside and reset the electrical box so that the dryer will start again. Is there a...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101';
Aug 06, 2011 | Kenmore 400 6942 Dryer
My Maytag MED9600SQ0 will not start. I have tried the following:Cleaned all vents, pulled plug from wall socket for 2 hours, and placed back in to reset;activated the - + buttons to reset the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2010 | Maytag MED9600S Electric Dryer
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Hoove HM6316M Dryer not drying
Where was the water leaking from ?
Has it leaked onto the dryer electrical connections ?
You need to check if there is a circuit board behind the fascia panel.
please let me know these answers
good luck
Jan 25, 2009 | Hoover HW6 160M Front Load Washer / Dryer
Whirlpool Dryer Help
Hi theres 2 things that can cause this #1 a dirty vent to the outside. #2 a dirty lint filer , Take the lint filter out & run hot water through it. If water wont flow through the screen, Its gummed up by Bounce sheet residue, Clean the filter . It should be ok
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer not drying - also lets in water
does water also come in when the machine is off, if so then a solinoid at the back where the hot and cold water pipes connect to it...
However i need more information to give you a perfect solution...
hope this helps get back to me if it dont ill try my best...
Jan 17, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer not wrking - letting in water
Does the water come in all the time? If so turn off each supply line faucet to identify which line is leaking and take that valve inside the washer apart and clean it out, if not completely replace that module. Let me know more about what exactly is going on.
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
69 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
