Kenmore Elite Topload Electronic Controls
Hi, I have replaced both the circuit board and the motor on this machine, however, when set on heavy duty and you select a small load the motor only hums once the tub has filled with water. If you increase the water by going to a half size load, on the water selector, the motor will start and appears to operate fine.
Model 110.20096993
Serail CK4603095
Thanks
bppaulssen@albertahighspeed.net
    President:
  • 1,314 Answers
Try replacing the start capicator on the back wall of the washer small black cylender with two wires on it ps your old motor is good if this fixes it
Posted on Jan 15, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Washing machine not spinning
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Nov 01, 2007 | GE WJSE3110A Top Load Washer
I have a Kenmore heavy duty washing machine model C110. When the machine has a full load and a high water level, it leaks, but when the level is lower ( small load ) it is ok. Also under the machine on the...
The water leak is from the white tub cover on top of the tub. The seal needs replaced.
The oil is from the transmission.
I honestly would replace the washer.
Jan 12, 2010 | Kenmore 24032\24036 Top Load Washer
Gets stuck in cycle I have to turn the knob to get it to continue. The machine is the heavy duty large capacity I can't find a model #
Looks like you need a timer. If the model number is really gone there should be a part number n the timer. look everywhere around the door/lid and even on the back. Eric
Aug 12, 2009 | Washing Machines
Kenmore 80 Series Heavy Duty washing machine suddenly will not drain. Tried different settings, nothing.
Unplug washer for 10 min to reset curcuit board. Then select the spin cycle. Selecting too many cycles in a short period of time can confuse the little brain in the board.
Apr 30, 2009 | Washing Machines
Kenmore Heavy Duty Dryer
If the dryer is still powered on but the motor stops, it sounds like the over load in the motor is cutting out and the motor will have to be replaced.
Feb 23, 2009 | Kenmore 63942 Dryer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Speed Control only works in Heavy Duty
sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Apr 10, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
