Question about Motorola Mobility RAZR V3
I have an older model motorola razr that the screen went blank but it is stil working.
  • 1,188 Answers
Yes this is the most common problem with the RAZR.
There is a small cable connecting the screen to the keypad part of the phone. This cable is called a flex cable and fits through the hinge of your RAZR so that the screen and keypad are connected even as the phone opens and closes on the hinge.
BUT, this cable often wears out or can even be severed even a slight bit, and the phone would then work, but only the bottom half, the screen would be dead. I fix this issue for people more than any other cell problem. You need to have the flex cable replaced.
Posted on Nov 28, 2009
SOURCE:
Blank screen, flashing keyboard, confusion
My Motorola Razor cellphone all of a sudden went blank, i took out the battery and put it back in and turned it on, but the keyboard just flashes and the screen stays blank, what do i do?
Jul 27, 2009 | Motorola Mobility RAZR V3
My Motorola Razr v3 cell phone's lcd is blank
unscrew it and change the flex to enable it view programms
Jul 17, 2009 | Motorola Mobility RAZR V3
Blank screen
menu/contacts/select teh options and scroll to copy all contacts
Dec 18, 2008 | Motorola Mobility RAZR V3
Blank screen
you need to have the flexcable replaced.
Jun 29, 2008 | Motorola Mobility RAZR V3
Razr v3m
The Flex cable probably went bad on it and yes it can all of a sudden so this.
Mar 20, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razr V3
this problem has probably occured due to the phone being knocked. i used to have a motorola l7 slvr and it did exactly the same, i found that if you hit the back of the phone fairly hard the screen would come back on. im not sure if it is the same for the razr but hey its worth a try. ti be honest i think motorola are terrible mobile phone manufacturers but great 2way radio manufacturers
Mar 17, 2008 | Motorola Mobility RAZR V3
Blank screen
this happens either when u r razr was dropped or have gotten wet...If it fell u need to remove the four screws on the screen and pry the cover off with a possibly thin knife.The flex cable is located at the top left hand side of the screen. you need to take this off and reseat it again.try powering on the phone before u close it back again to ensure that it works.If this doesn't work either your screen or flex cable is gone, then u need to check a phone repair shop.you need either a t6 or a t4 screw driver set to remove the four screws located under the the 4 rubber fillers on the inner screen.
sam !
Feb 19, 2008 | Motorola Mobility RAZR V3
Razor screen went blank
i tried some electrical contact cleaner (brake cleaner WAL-MART .89 cents) on the hinges. Open ti back and forth several times. NOTE: do not spray alot, just a little at a time. Then it got squeaky and started working. Then I sprayed a little WD-40 on the hinges and it works fine.
Nov 16, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 (black) screen has white blank
Well i suggest that you take the case of your phone and have a look at your screen maybe some of the screws have gone missing or the screen has just worn itself out? . Note youll need a t6 or t7 torx screwdriver to do this , hope i helped
Oct 17, 2007 | Motorola Mobility RAZR V3
Dropped it and screen went blank
take the phone and have them replaced the lcd or flexcable
Aug 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
115 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
