Question about Hotpoint Aquarius WMA56 Front Load Washer
Aquarius 1300 spin trips residual circiur breaker
Washing machine mostly on a spin cycle but also on other wash cycles frequently trips the circuit requireing a manual reset. Machine also seems very noisy on spin with some obvious vibrations of the machine
  • 139 Answers
Hello
There can be two possible reasons for it triping..
Firstly what im pretty sure it is, the motor... either your motor is faulty or your carbon brushes are worn... Im saying this because when the motor has to work at its hardest during the sping cylce it just cannot cope..
The other thing could be is that the drum has play within it and when spining quickly it is cathing the heating element probably already damaged it and therefore triping.
There your most likely faults
hope this helps.
The motor is located at the at the back on the bottom of the drum.
the heater is located at the back on the bottom of the drum .
Most likely is will not be the heater as it is more common on the older hotpoints.. But i thought id mention it
Hope this helps......
Posted on Jan 15, 2008
After wash cycle, water is pumped out but circuit breaker is blown when spin cycle starts.
Will the tub spin if you move it by hand? A motor will usually only draw excessive amperage if it cannot move easily... Also, take a look at the terminal block where the power cord attaches to the machine for burnt connections, a bad connection can cause a breaker to trip, same as a 'dead' short. Terminal Block WPW10245259
May 25, 2016 | Washing Machines
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
Whirlpool washer machine WTW5790SQO washer trips circuit breaker half way through cycle
you are pulling to many amps see if breaker is faulty first.....see if washer is in the spin and jumping around when this happens run washer with out wash in it and see if it does it something is pulling to many amps to blow breaker or could be just a bad breaker,,,, pulg something else in the wall plug that the machine is plugged in to (like a toster) and see if it trips then if so probably the breaker
Nov 11, 2011 | Whirlpool Washing Machines
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
Put washing machine on and it automatically trips
If it is tripping the breaker, the first question that has to be asked is how many other appliances do you have on the same circuit. When the washer goes to spin it will start to draw slightly more electricity than once its at a full spin(much like the energy needed to get a car moving is greater than once it is up to speed), but it is not enough to trip the circuit unless there the circuit is already near capacity.
Before attempting to check electric of the washer, check and remove items from the circuit. To know what circuit runs your washer you will need to take a pigtail or a radio and plug it into the outlet Go to circuit breaker box and turn on and off circuits until the radio goes out.. Once you acertain what circuit your washer is own, go throughout the house and see what circuts are shared with the washer. Unplug any that are shared with washer. Your Hotpoint needs no more than 15 amps to run but if your overloaded on the circuit, the spin is enough for it to trip the circuit. Try washer and see if you go through the full cycle.
Oct 13, 2009 | Hotpoint Washing Machines
Flashing lights and trips the electric
Are you around when the breaker trips? It almost seems as though an electrical connection is getting wet. Especially if it won't let you reset the breaker. Another reason for not letting you reset the breaker could be an overload that tripped but that to me would be within the machine, it shouldn't trip at the panel. You get pull the machine apart and check for these things. Look for and wetness or wire connections being crossed, anything like that. Something at the spin cycle is shorting out and tripping out your breaker. Also is your dryer circuit properly sized (30AMP Breaker with 10/3 wire)?
May 26, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
I believe the problem is in the fus(breaker). I would say that it is the thermal fuse in the machine but it usually goes out before the breaker does. The breaker has gotten weak over the years. You have a hi limit on the machine as well but I doubt this is it. Let me know how you do.
Feb 07, 2009 | Hotpoint Dryers
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Not completing the wash cycle
Does this happen every time or once in a while? If it happens everytime, I would guess there is a shorted spot in the timer. If you can put it into the spin cycle manually, then the motor is not shorted. It will be hard to diagnose it from long distance, but if it is tripping the house breaker it has a dead short somewhere. If it only happens sometimes, check to see what else is on the circuit that might be running at the same time. It pulls the most amps when it goes into spin, spiking around 16-20 amps. If you have other things running on a 20 or 30 amp breaker it could just be the curcuit is overloaded at that point or the breaker is weak. If we can narrow it down to the timer, it is a pretty simple repair, but some of the timers are pretty expensive. Post back with the exact model number if you need more help.
Oct 18, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint Aquarius WMA56 Front Load Washer Logo
83 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
