Question about Sony Cyber-Shot DSC-F717 Digital Camera
My cibershot DSC-F717 does not have anything in the viewfinder and the LCD displays the settings and options.The screen is black with yellow words and numbers Also my zoom will not work. The LDC does not have an image on the viewfinder nor the LCD. I do have the LCD setting options displayed. The zoom will not show where the setting is on the LCD and I have checked all the settings (the focus on the zoom mode, conversion in the set up turned to off).
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 29, 2009
SOURCE:
LCD screen is black and will not display the image
The flexible cable to the LCD is to be checked for defects like breakage. Or the LCD is defective and both are a common problem.
If you need any spare parts mail me.
sivaram v
videolabs
Sep 01, 2013 | Sony Cyber-Shot DSC-F717 Digital Camera
I have a sony DSC-F717 and when I look at my image through the LCD screen everything is tinted yellow... this problem is intermitent, it comes and goes... downloading to computer, the pictures are fine......
The chip that drives the image to the LCD is faulty or the LCD screen itself is faulty. The problem will most likely get worse or continue indefinitely. The only solution is to contact customer service and see if you can get it repaired. If it is under warranty it should be a free fix but if that expired you will have to pay to get it fixed. Luckily though, the camera sensor is fine and it still will function but your display will continue operating oddly.
May 03, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Good afternoon. Literally, not long ago on my camera screen and viewfinder have to give a touch of yellow color. But this effect was not reflected in tailor photographs. In what may be the problem? Sorry...
This sounds like a colour balance problem. If you have set colour balance for daylight, then pictures taken in artificial light will be yellowish (or greenish under flourescents). It is best to leave the colour balance set to "auto".
Nov 04, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony /DSC-T1: smeared or black lcd screen and pictures
noavatar_s.gif jmartens1
Rank: Guide
Rating: 100%, 1 votes
said: To those in the US affected by this problem..... http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161 I went, and it appears that Sony will repair my camera for $20 S&H. The link also provides a verification test using the movie function. BUT THE OFFER EXPIRES 3/31/2010. === It has come to our attention that a limited number of products, manufactured before March 2004, and incorporating a certain type of image sensor device (CCD), may exhibit the following:
  • When the product is used in camera mode, the LCD panel2_bing.gif and/or electronic viewfinder exhibits either a distorted image or no image at all.
We have determined that this only occurs in a limited number of devices, but may be accelerated if they are exposed to hot and humid environments.
Until March 31, 2010, Sony will repair, free of charge, the following product models exhibiting the above-mentioned symptom where it is caused by the image sensor device:
  • DSC-F717
  • DSC-T1
Feb 07, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
No image on LCD while all else seems normal.
Go here:
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCF717&news_id=161
Sony had a certain issue with the CCD chip on this camera. If it's this issue, they'll fix it free plus $20 until March 2010.
Dec 12, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Built-In Flash Not Working
Hi, I am certainly not an expert, however, I was having problems with that also. In addition, my viewfinder was almost black & white with a greenish tinge.
Come to find out there is a reset button inside where the battery is. You might try taking the battery out and leaving it out for 5 min. or so and see if this works. It fixed mine but not the screen. Then I tried the reset and that did not work. Then I took the battery out and then it worked!
When you reset the camera, you will have to re-enter your setting, ei, dates, etc.
Hope this helps.
Claudia
Sep 01, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
No image
Sony is fixing this through Sept. 2008!
http://esupport.sony.com/perl/news-item.pl?news_id=161&mdl=DSCF717
Apr 17, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Re: No picture...
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Feb 19, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
Oct 22, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
No image but data info etc. OK on LCD and EVF
Yess CCD problem- contact Sony they will either replace or offer a discount on a new model as this is some years old now.
Sep 09, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
105 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
