Question about Ricoh Aficio AP3800C Laser Printer
Ricoh ap3800 error code sc261
Sorry for the earlier fault definition.
it is error code sc261 and it is not taking the blue ink cartridge. always shows auto power off.
could you pls notify with a proper solution on ravi4chippu@yahoo.co.in
  • roshini Jan 20, 2008
    thank you very much for the valuable information and advise. problem not yet solved awaiting spares and most likely by tomorrow will be able to fix it....will keep you posted the result soon.
    great support and highly appreciated.
  • 417 Answers
Hi there the following is taken from the service manual. Thanks J
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
Posted on Jan 16, 2008
  • 1 more comment
  • Jason Collin
    Jason Collin Jan 17, 2008
    Have you checked the fuse on the power supply board? Also try plugging it into a different wall socket and changing the power cord.
    Thanks J
  • Etienne Oct 02, 2012
    what is the HP sensor ?!
    what is a LD HP Sensor ?
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
Canon pixma mp250 showing fault code e05 will not print
Try to stick with original cartridges... Generics only waists time and money
Mar 15, 2012 | Canon Office Equipment & Supplies
My printer always shows E22..wht the meaning that! how to solution...
The E 22 error code is a carriage error, which means there is something wrong in the cartridge area. To fix this error, turn off the printer and unplug it. Remove all of the ink cartridges and check for signs of leaking or damage. Now look closely inside the cartridge slots for dried up ink and use a tiny bit of alcohol on a QTIP to clean the ink off the slot. Reinsert the cartridges and plug the printer back in and turn it on. The error code will disappear
Feb 04, 2011 | Canon PIXMA MP160 All-In-One InkJet...
WHAT DOES THE SC 38 MEAN ?? WHAT FAULT DOES THIS SERVICE CODE REFER TO?? I HAVE A LANIER 2138 COLOUR LASER PRINTER, (SAME AS RICOF AP3800 SERIES)
SC is for "Service Call". The error may be caused by a defect or an irritation of internal sensors.
Ricoh recommends to physically switch off the printer, wait for a few minutes and power on again. (Irritation by change in surrounding temperature)
If you recently replaced any movable parts inside, remove it again and reseat, many parts inside are checked by sensors for proper seating.
If this does not help, you need to call Ricoh customer service.
Feb 09, 2010 | Ricoh Aficio 3800CMF Laser Printer
Ricoh error code sc291
There's a list of Ricoh error codes right here: http://www.tecnodigitale.com/riparazioni/pdf/Codici_errore_Ricoh.pdf but it doesn't indicate an sc291 for the 3800 or for any other model for that matter.
There are usually contacts on the cartridge that interface with a reader in the printer to detect the chip in the cartridge. Examine a cartridge and look for any electrical contacts, make sure they don't look damaged or dirty clean them with 98% isopropyl alcohol. With the printer powered off and upplugged, try to find the corresponding contacts inside the printer for each of the contacts on the cartridge, clean those too.
If that doesn't change, try a different cyan cartridge, if that still doesn't work you will probably have to get the machine serviced.
Jan 14, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
241 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
