Question about Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor
Buzzing sound coming from monitor speakers
A high pitched buzzing sound comes out of the monitors speakers when no audio is playing. The monitor is hooked up to a macbook. This problem just arose when I hooked my laptop back up to the monitor, but I have not changed any settings. What should I do?
Thanks,
David
Check your leads, chances are it's a faulty/dodgy lead coming from your macbook to the system.
Posted on Jan 17, 2008
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Monitor will start out just fine, then will start a high pitch buzzing sound. After a while the power light stays on the monitor but the screen goes blank. If I turn the power off then on it will come...
The power supply of your HP Monitor is failing - it is not able to sustain the voltage needed to maintain picture.
It is possible that solid-state components could be replaced on the circuit boards to fix this situation, but for the trouble and expense I must recommend replacement.
I hope that helps.
Aug 21, 2010 | HP Computers & Internet
Buzz coming from speakers. x2 gen 19 inch lcd been working for 2 years on old xp and now win7 no problem with win7 for 4 months before this. checked for updated sound drivers. plugged in usb powered...
Buzzing is usually caused by bad audio ground connection. Try insert and reinsert the audio cable first. It can also be the sound card. Try using the MP3 player as the sound source feeding the monitor, if it still bad then it can be problem in the DC filter caps in the power supply, or bad sound IC in the audio board inside the monitor. Please post back what you find.
http://s807.photobucket.com/home/budm/allalbums
May 07, 2010 | X2Gen MG19VT 19" LCD Monitor
I am experiencing a high pitched buzzing noise coming from the dell monitor #cn-0p0151-64180-3a5-3642
CRT monitors and TVs do this after some time. It is caused by high frequency alternating fields - think transformer - when things get old and loosen up enough to vibrate.
The good news is that it is time to upgrade to a modern flat screen monitor, and this will be cheaper than repairs on your old tube.
Dec 14, 2009 | Dell E773C 17" CRT Monitor
There is a loud buzzing/static sound coming from my monitor. It changes pitch and sound a little with different screens. The visual display does not seem to be effected. Just a terrible sound. Any ideas...
Start by getting a can of the electronics spray air and blowing out and areas that may collect dust.
Also jiggle the power cord attached to the monitor and watch to see if it changes the monitor or the squealing at all.
Seems more like a lose power connection, but eliminate the simple possibilities before moving toward circuit board issues etc.
Also do you have any other high powered electronic devices near the monitor?
That can effect it's performance as well.
Jul 23, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
Monitor Audio FB212 buzzing
Apparently there is an issue with the 10000uF 80V capacitors. They are poor quality ones and the issue is that the dielectic forms hydrogen internally which eventually blows the dielectric out.
Dec 31, 2008 | Monitor Audio FastBass FB212 Subwoofer
Sound from monitor speakers distorted and high-pitched
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 16, 2008 | Computers & Internet
Speakers Buzzing Whilst Playing Music
sounds like interferance try moving the speakers around maybe away from the monitor and try turning off any thing elec around your pc to find out maybe what is causing this
Dec 01, 2007 | Philips MMS 460 Computer Speakers
High pitched buzzing...
noisey yoke? Listen thru an empty paper towel roll cylinder to isolate---
Nov 17, 2006 | Sanyo DS27910 27" TV
Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor Logo
301 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
syspro
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
