Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother Advantage can't fax, always busy
  • 146 Answers
You mean you can't fax out or you can't get a fax because the line is always busy. I assume you already know it doesn't receive it only sends so we'll go from there. This model seems to have quite a few problems with the fax and it is usually in either the selector the processor or a switch. Make sure all your covers are closed tight if they are it's not the switch but some other problem. Your probably better off getting a new one because the repairs can be fairly expensive from $50 to $90.00 and I have found this model on the net for around $79.99. Hope this helps.
Posted on Jan 14, 2008
Brother 7340 not sending or receiving faxes line busy
sounds like the modem on your printer has failed depending on how old it is most likely it would be cheaper to buy a new printer
Mar 24, 2014 | Brother MFC-7340 All-In-One Laser Printer
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
The fax machine will not faxes, it prints out as busy.
make sure the cable is in the LINE socket not the TEL socket as this will stop connection..
Jul 20, 2010 | Brother IntelliFax-2820 Laser Fax
Brother Fax 2910 Connection Problem
It's a problem with your long distance carrier
Jun 28, 2010 | Brother IntelliFax-2920 Fax
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
When I try to send out faxes, it always say the line is busy.
are sure that you have the right plugs plugged in? to the right jacks on the machine
Jan 12, 2009 | Brother IntelliFax-4100e Fax
Printer busy
sounds like the faxes are stuck in memory
look in the Troubleshooting section of the manual
Jul 17, 2008 | Brother IntelliFAX 4100 Laser Fax
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
364 people viewed this question
James Cagle
James Cagle
Jim Keysor
