Question about Toshiba 62HM95 62" HDTV
Bright light on bottom of screen
I have recently noticed a bright light on the bottom (middle) of the screen that is especially noticeable when the screen is dark. I put in a new bulb and it is still there. What is causing this?
  • 50 Answers
Sounds like your light engine. Very easy to replace.
Posted on Feb 16, 2008
Top 1/2 of screen very dim and bottom 1/2 very bright
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 04, 2016 | Televison & Video
Mytouch 3g slide screen doesnt light up
I have the same model but 4g. I often notice the same problem, but once i step out of the full sun/bright lights, i notice that it is infact dimly lit. This can be adjusted by opening settings > display > brightness > turn off automatic brightness and set the level to at least %50.
now, if your screen is literally too dim to see, try this : Press the power button quickly, now unlock the screen by sliding your finger from the bottom center up to the top center and releasing, all in one fluid motion. This is the default screen-lock gesture and the brightness, if this is indeed the issue, should go up one notch upon unlock. From there, follow the above procedure to turn up the brightness.
hope that helps
Sep 11, 2012 | HTC Black Mytouch Slide 3g Tmobile...
Bright Spot
A fixed blue area on screen may be a display panel (main screen unit)
Here is a link for the boards etc this set uses--take your pick:
http://www.shopjimmy.com/sceptre-x460bv-f120
May 17, 2012 | Sceptre 46 X460BVF120 LCD TV
Two blue dots on the screen
its sounds like the guns has burnt your yube, when switching of does your tv show a bright circle in the middel, or while watching. Smack your tv on the side while on see if the picture goes away or make a bright circle in the middel, this is caused by a bad solder joint but you wont get rid of the bunt pixels sorry.
Nov 26, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
When I take a pic all I get is bright light
Sounds like your lens shutter is not closing. This results in very bright pictures(overexposure). I suppose it could be a shutter speed setting. Look around in the camera setup menu for a "camera reset" or "initialize" command.
Nov 13, 2008 | Samsung Digimax D53 Digital Camera
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Bright spot on screen.
I'd say that's just the way they're made. The background light for the screen just doesn't illuminate evenly. If it's noticeable enough I'd try to get it replaced under warranty. This can also happen when the screen is pushed and it gets damaged, but if it's happened twice it's probably just the way they're manufactured.
Nov 09, 2007 | LG 32LC7D Television
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
Streaking inside of screen
Philips screens tend to be very tough to remove as if you are not careful on removal of the screen frame bolts then the whole screen will come falling off.
Mar 19, 2007 | Philips 44PL9523 44 in. Rear Projection...
Toshiba 62HM95 62" HDTV Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
