Question about Zhone (6218-I2-200) Router
I need to change my password and username!!
When I go to my ip address page it appears the log in window. I know the password but, I want to change the user name and password.
    Novelist:
  • 139 Answers
After you log into the router, from the main screen, click on "Management" > "Access Control" > "Passwords". You can enter a new password here.
More details are available on page 86 in this manual on the Zhone web site.
Good luck...and I hope this is helpful!
Posted on Jan 14, 2008
6ya staff
SOURCE:
How do i change my password and username
Log into your account by opening the browser window and entering the IP address (for example, 192.168.100.1). A login screen will appear, asking for the username and password. 3. Change your username and password in the Administrative or Security Tab
Dec 03, 2016 | Computers & Internet
How do I change the "Pass code" on my wireless Motorola surfboard modem ???
If you mean the wireless pass code or Passphrase you need to log onto your modems web page which normally sits at IP address: 192.168.100.1. In the wireless section there is the pass code update field.
Dec 30, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Need to change my password how do i do that?
Welcome to Fixya. If you want Password on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure.
Thanks for using Fixya.
Feb 14, 2011 | NetGear WGT624 Wireless Router
Wish to log on to router
In order to log onto the router, you will need the router's password (not the wep/wpa passkey, but the other password). You will also need a computer that is connected to the router (does not matter if its wireless or not). First, you will need to know that router's IP Address. To find this, open a command prompt window on your computer, and type in the command "ipconfig", and hit enter. Your router's IP will be shown as the default gateway. Next, open up a web browser, and, in the address bar, type in the router's IP address. A login window will pop up, requesting a username, and password. Depending on the router, and whether or not it has its default settings, these are some of the possible combinations:
  • Username: admin, <blank>, administrator, comcast, or even password (these might not be all of them, they are just common ones)
  • Password: <blank>, 1234, admin, password, default
Once you successfully enter the username and password, you are logged into the router.
Mar 01, 2010 | Computers & Internet
How do I portforward my GT704WG to UDP 5198 and 5199?
It is important in order to setup port forwarding on your router that your computer has a static IP address assigned. Port forwarding will not work properly without. If you don't know how to do it, look at this guide for different operating systems (or come back here and leave a comment with your operating system details and I walk you through the steps.)
Once that is done, open a web browser and enter the IP address of your router in the address bar. the default IP address should be 192.168.0.1.
  1. When you are logged in, click the Setup / Configuration link.
  2. Then click the Advanced Setup link in the left panel of the page.
  3. Click the Begin Advanced Setup button.
  4. Click the Port Forwarding link in the left panel of the page.
  5. Enter the values 5198 and 5199 in the IP Port Range fields.
  6. Select UDP from the drop-down menu and the static IP address of your computer in the IP Address field.
  7. Click Add.
  8. When you have entered all ports you want to forward, click Save and Restart in the left panel of the page to save your changes.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 18, 2009 | Actiontec GT704WG Wireless Router...
Windows adds http:// to 192.168.1.1, and I get an error page instead of router pages.
Did you change the IP address of the router? Can you ping the gateway IP?
Jun 08, 2009 | Linksys WRT160N Wireless Router
My D-LINK 604 router doesn't respond anymore
For Windows XP operating system follow this method:
Before doing this process disconnect all other pc or devices that connect to the network through your pc or through the router.
1.open the control panel and go to network connections and right click the connection that is active and select properties and select tcp/ip and click properties and change the ip settings to automatic.
2.Now connect the pc/Laptop to your router through wired port.
3.open your internet explorer and type your router's default ip address in the address bar.The login page of the router will open.In this page give the username as "admin" and password as "admin" in some router the password will be "password" ( this passwords are default.if you have changed the password login with that password)
Hope this might solve your problem.If not feel free to contact me.
May 17, 2009 | D-Link DI-604 - 4-Port Broadband Router [...
Changing a Dell 3010cn IP address and Storecenter
Print a settings page from the printer. If you are not sure on how to get the settings page, download the user manual from support.dell.com, there should be instructions in there on how to get this. Once you have the settings page locate the IP address on the print out. Take this IP address (which may be different then the one you want to use) and open internet explorer, put the IP address in where you would normally type a web address, hit enter. This will take you to the embedded web server of the printer. Once you are there, you can look for printer settings, ip address or TCP/IP address. Once you have found this, you can set a static (meaning it will not change, unless you change it) IP address (the IP address your tech person gave you) and submit the information to the printer. The printer must be on and in the ready state for this to take hold. If you are prompted for a username and password for the embedded web server, dell default username in small case is admin, leave password blank or username admin, password is password. To confirm that the address has taken, print another settings page from the printer.
Nov 14, 2008 | Dell 5100cn Laser Printer
Air port
All routers have a username and password on them, sometimes it doesn't come default and you have to set up. By default the username is admin, and the password is blank. Hope this helps
Oct 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Zhone (6218-I2-200) Router Logo
342 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
