Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius wf 541
Lights 3 and 4 flash simultaneously (rinse hold and mini load)
Water comes in, goes straight out and the drum stays still (although free)Onoff button flashes very quickly
  • 2 more comments
  • Anonymous Jan 20, 2008
    Have same problem - WF540 machine. Wash enhance light & rise hold light on & flashing together with on/off light flashing furiously or mini load light together with on/off light - water going in and straight out. I've unplugged machine hoping it would re-set itself, but to no avail. Also, just checked outgoing pipe, this seems to be ok. Any other suggestions? All welcome..
  • Anonymous Sep 25, 2008
    yes I have very same symptoms as others water comes in and straight out again light 3 and4 flash and on of button. this seems like a common problem with the hotpoint aquarius wf541.
  • steph_l_sinc Sep 29, 2008
    We have the same problem with our Hotpoint WF 541 (only about 15 months old). It seems to work when its empty but as soon as you put any clothes in (even just a couple of light items) it stops part way through and the 1st and 3rd lights flash (wash enhance and rinse hold) and the on/off button flashes rapidly. I've tried cleaning the filter at the front of the machine, unplugging it, adjusting the drain pipe - any other ideas?
  • Anonymous Mar 31, 2014
    How do you get
We have a WF 541p which keeps throwing its belt off (even the replacement belt) , though the small spindle has guide teeth the large drum wheel seems to rely on friction to keep it alligned on its smooth exterior ( there are no guide walls on the outside of the wheel) it is only 16 months old, we live on an island so need to try to repair it ourselves.any suggestions gratefully recieved.I guess the bearings may have gone, we accepted its known as a noisy machine but expected it to last a little longer! Davce- Isles of Scilly-Cornwall
Posted on Jan 29, 2010
Had similar prob with wf430, 3rd & 4th light flashing (rinse hold and time saver). read previous entries, checked for blocked pipes at back but all clear. Took out some of my washing and tried again with a lighter load and it seems to be working now. Not sure if perhaps we overloaded it, despite its 6kg washing capacity boast. Hope this helps
Posted on Feb 09, 2008
    President:
  • 1,294 Answers
Check your drain pipe behind. This is supposed to be approx 3 feet above ground level; then the hose goes into the stand-pipe without being too tight. If this does not work, click "thanks for trying"; your prob will be back for someone else to solve.
Posted on Jan 15, 2008
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Mini load, rinse hold and on/off lights flashing
Check the relay and the control board. Something is telling the inlet valves to stay open and allow water. If you just bought and replaced the inlet valve that would be your next stop
Feb 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
580 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
