Question about Samsung HP-R4252 42 in. Plasma HDTV
E & F buffers: how can the average guy chang/replace them
How can I or any average guy buy and replace an E or F buffer??? What tools are needed? Or, how can we purchase a panel with the buffers and replace the panel. Is it not like putting in a new mem. card in a laptop???
thanks john
  • jfred88 Feb 12, 2008
    Thanks for your response. I'm not sure what is needed. I have a yellow verticle line(made up of numerous yellow lines and it is 2 1/4 inches wide) just to the left of the center of my screen???????
    Sergeant:
  • 261 Answers
You have to know the part # and order from samsung. IF your not sure, i can step you thur the process and then we can go from there. Have a good one. GURU JAY.
Posted on Feb 06, 2008
How can I stop the buffering on my high speed internet?
It's not only for You..While watching Videos Online the Internet speed get slow ...Also the Online videos buffer and display in screen..So you can better pause the Video in Youtube after select the video.Then you can see a buffer lines scroll through end.After that You can play it.You can watch it without buffering.You can check the speed of the internet at Scanmyspeed. com here You can check the speed in Mbps and MBps.
Jun 26, 2012 | YouTube Videos
Makita 7" 9227c I
the part number is 224517-1 and you should be able to find it at any hardware store that sells Makita tools or you can buy it online from "makitausa.com" they also have a service center locator that you can use to buy it locally. Let me know if you need more assistance.
Jun 17, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
Picture is starting to flicker, then it will turn off and turn on automatically, it's trying to reset itself. What could be the problem and can it be fixed? Thanks, Martin.
The buffer boards are most likely bad at this point. With my Philips TV, the heat of the Plasma caused mine to go bad.. and the connectors from the buffer boards to the Y buffer control weren't tight. I took the TV apart and tightened the connections and it works fine now. If it's warranty take it in and get it fixed. If the TV is out of warranty, you can fix it yourself or get someone who is tech savvy to do it. There are plenty of guides on the Internet to do it. Worse case is you have to purchase new buffer boards. In some cases, depending on the TV, it's not worth the time money to fix... but with a 50" unit... I would try. There are also plenty of guys like me out there that might buy it from you and fix and sell it.
Sep 28, 2010 | LG 50PC1DRA 50 in. Plasma Television
Wont come on and there is a blue light flashing
for more info on this set please check out http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
if will tell you how to trouble shoot this tv. these tv's are known for two caps in the power supply to go bad and they need replaced then you have to test the sdr buffer boards if they are bad you need replacement boards or you can send them off to be repaired.( Repairing the buffer boards is a lot less then replacing them ) the link for the repair guy is on the page. this guy also sells the repair on ebay but if you contact him directly i beleave the price is lower. just tell him you were send over by home theater shack.
Jun 26, 2010 | Hitachi P50H401 50 in. Plasma HDTV
HPT5054 50 in. HDTV-Ready Plasma Television: Samsung HPT5054X/XAA - No picture, Sound OK, Have ...
It's not the x main. 90% of the time it's a y buffer that goes out. It's usually the top buffer. 3/4 of the time the buffer takes out the y main board too. You cannot just replace the y-main or buffer because it will just burn out the other within seconds. Also about 1/4 of the time it'll take out the top transformer on the power supply too. The solution? First disconnect the power to the y main board. turn on the television and check the voltages coming off of it. Careful it's high voltage 208V! Remember it's DC too. Then disconnect the buffers from the y main board. You can try powering the y-main up to see if the little LED lights up. This does not indicate it's working though but it'll tell you if it is possible to fix. The fixes for these boards is only for electronics guys. It usually involves replacing 1-3 capacitors and 1-4 FET's. Since a bad buffer can take out a good y main in seconds it's usually recommended that one replace all 3 boards at the same time. It's a $250 fix. How do I know all this? I've now repaired 5 of these televisions. I owned one and spent close to 600 repairing it. I bought misc parts and broken sets online for months before I had 2 different repair guys walk me through the process of repairing them. I had so much cash tied up in parts that I bought 3 more dead sets and repaired them to justify all my spending. I've never had an x board fail. I've had EVERY top buffer fail. I've had all but 1 y-mains fail. and 1 lower buffer fail. I've also had the y buffer fry it's top chip, blow a capacitor and FET on the y-main, and fry the top transformer on the power supply before my eyes. It only took 5 seconds. Replacement of the 3 y boards will almost always fix the sound but no picture problem. Hope this helps!
May 16, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
No picture, just sound, blown y buffer board twice1
a4.. there are 2 of them, upper and lower buffer boards.. they control the top and lower half of screen devided horizontally, i have had many run ins with these sets. and usually the buffer boards arent cheap.
they plug into the ysus( y sustain).. its possible your y sustain is blowing the buffer moduals because one of its i.c.'s under the heatsink has popped on ya.. effectively creating a short that blows the buffer boards.
remove the buffer boards, turn tv on... feel the 2 silver heat sinks on that y sustain( beware dont zap urself.. just the tip of your finger on the heatsinks)
you may find that one is cold and one is hot...if so, you need a new y sus and probably to replace the buffer boards the a4 upper and a4 lower.
If you get a new ysus.. plug the a4 upper and lowers into it, look at your picture.. if ur missing the top half the top buffer is blown or lower half the bottom buffer is blown. or..no picture they could both be blown..an easy way to tell if u have no picture to diagnose is..touch the heatsinks that sit over the chips on the buffers..if they are red hot.. they are bad and shorted internally.
Dec 05, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
We have lost a two inch wide black section on the right side of the plasma panel, any ideas
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Oct 25, 2009 | Samsung PS42P2S 42 in. Plasma Television
My 50'' Samsung Plasma has dead screen after only 2 years
welcome to fixya!
without doing voltage checks, my best guess is this:
Plasma hpr5053 or hps5053 models will burn out a buffer board or both, there are two buffers and the Y board.
I usually change all 3 at once, but if on a budget you can try to remove one buffer and see if you get half picture (upper or lower)
this is something only a technician should attempt. the boards cost $200 each (buffers)
$300-$400 (Y board).
if you actually get half a picture the Y and one buffer are good, a bad buffer usually burns out the Y board. and in really bad cases the panel is bad also (not common, but possible)
For part#s , specific help you can post a model# , but again this is a repairmans job not something the average customer can fix.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 27, 2009 | Televison & Video
I have the porter cable 7424 buffer/polisher. My problem is when you apply any pressure, even the weight of only the buffer on the car it stops spinning. You have to hold it up slightly lifting the we
The armiture has a winding problem, common in a lot of power tools. Replacing the armiture is not cost affective unless your time put into it is worth it, sorry. I recomend the Dewalt veriable speed, nice professional buffer!
May 07, 2009 | Porter Cable 7336 6 Inch Variable Speed...
Samsung HP-R4252 42 in. Plasma HDTV Logo
85 people viewed this question
Jerry Greenberg
Jerry Greenberg
