Question about KitchenAid 32685 Mixer
Classic Bosch universal mixer
Switch no longer will turn machine on. one moment it turned on, 15 seconds later nothing. Took bottom off and all connections were intact. Machine is 15 years old? Do I just replace the switch? If so , where might i find a switch? What is usual problem in such cases? Thanks for your help.
GPM
SOURCE: kitchenaid mixer speed
I have the same problem. I contacted KitchenAid they blew me off with
"I am sorry to have learned you are experiencing problems with your KitchenAid product.
Your model and serial number indicate that your 2005 model Stand Mixer is outside of the warranty period, however you may find the part or repair for your appliance locally by contacting an authorized repair center in your area. To locate an authorized repair center please click on the following website link:
http://caservice.kitchenaid.com/
They obviously have a defective poor product now and will not stand behind it!!!
Posted on May 10, 2008
SOURCE: Mixer just won't turn on -speed control jammed
Well, I half fixed it thus far anyway.
I got the speed lever freed up - just by jiggiling it back 'n forth, standing from behind with the mixer sitting upright on my counter. I was surprised when it just clicked free. With a tiny flashlight, I could see that the lever mechanism worked from a sharp angle to move the bar which pushes the circuit board back, (which is on springs) which lets the contacts on the circuit board close up, to run. Pull the lever back to off and the contacts separate, breaking the electrical current.
I sprayed some DW-40 lubricant on the little gear inside where the speed lever joins up, and it freed up even more - works very smoothly now, pushing the circuit board back 'n forth nicely.
But now when I plug it in, nothing happens. Lever works fine, but no spark.
Maybe I should not have used DW-40 ?
Maybe I should have used alcohol spray instead ? Or just plain air ?
I may have disturbed the electrical contacts or dirtied something ?
It's hard to tell.
I'm going to let this dry out a bit with the back cover off and see what happens in the morning.
I'm beginning to think this model was made in China or something.
These things never died so easily in my parents day.
Posted on Nov 09, 2008
  • 7 Answers
SOURCE: KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Posted on Dec 15, 2008
SOURCE: Power On Problem
if you remove the top you will find a tiny fuse wrapped in a black band on the left side from the back. It connects two white wires which power the top-side motor brush. Most likely this needs to be replaced. You can check by bypassing it with roach clips or a copper wire. Unplug the machine first and be careful!
Posted on Feb 09, 2009
SOURCE: kitchenaid k45ss won't turn on
Kitchenaid KSM150 Mixer's speed Off has become High and speeds 1-10 have become Off
The starting position for those top speed control plate screws with the lock nuts it 8 full turns in when you fit the plate. Correct adjustment begins in or out from that point. The bottom screw should have been left where it was to start with as that is for adjusting the start position so that when the lever closes the switch contacts to start the mixer the plate only starts moving when the lever moves to the second click. Try and get the bottom one roughly right and then work on the top ones. Turn it to the first click on the speed lever and then EVENLY adjust the 2 top screws to have the planetary turn 13 to 15 times per 15 seconds. Lock up the lock nuts and then check that the bottom screw is in the correct position with speed increasing a small amount as the lever slips into the second click.
Sep 15, 2017 | KitchenAid Kitchen Aid KSM150 Artisan 5...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Does anyone know how I could open the base of a Bosch universal mixer MUM6N11 to expose the wires as they come into the machine.
Just take the screws off the bottom. Several need a long screwdriver to access. Then the top will lift off.
Mar 02, 2010 | Bosch MUM6610 Universal Series Stand Mixer
In middle of kneading dough, the machine stopped! I noticed that the gears that connect the bowl to the machine, stopped turning, when machine goes on, it makes a noise, but nothing turns.
Hi HENNY346. Your Bosch mixer is belt driven and from the description of your mixer’s symptoms I suspect that the drive belt has come loose or failed completely so it stopped driving the dough hook. You say that when you turn the mixer on, it makes a noise, which may be the motor running without any load, but your description of ‘noise’ is very vague.
The good news is that you should be able to diagnose and fix this quite easily (OK, maybe with a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty.
Here are links to two online parts vendors for your Bosch mixer that also provide an exploded view diagram along with part names, numbers and prices. They are: Cook's Quarters and AppliancePartsPros.com It can be very gratifying to go “under the hood”, figure out what’s wrong and fix it yourself. Good luck , I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Feb 23, 2010 | Bosch MUM6612 Universal Series Mixer
Noisy, high pitched whirring MUM6622UC/01 Bosch Universal Mixer
My wife's bosch mixer had a similar problem but it was a very loud grating problem. I talked to the bosch dealer in Utah, sorry, I've forgotten which one-- the one that does the repair. This is typically what happens: the seal on the blender wears out, which results in fluids from the blender dripping into the motor, onto the upper motor bearing. So, the upper bearing corrodes and is what is causing the bearing failure and the loud noise (needed hearing protection to operate it). I was lamenting the cost and time it would take to ship the mixer both directions (not actually that much compared to the price of the mixer), and he said he would sell me the bearing and the bottom replacement part of the blender that was leaking. So, I did the repair myself, but it took awhile, and I had to build a puller for the bearing to get it off the shaft, modifying a harbor freight gear puller. But it now is back to new. So, it was a success for me, but i would recommend anyone who isn't very mechanical to just send it off to Utah (again, I forgot the place, I think they talk about the shop in one of the other posts), and you will have a better than new machine.
Nov 08, 2009 | Bosch 700 Watts MUM6622 Universal Series...
Sunbeam 2359 Mixmaster No Longer Turning On
Could be switch failure or failure of another component due to age.
Oct 27, 2017 | Food Mixers
"clunking sound"
The plastic worm gear had teeth missing. I was able to order a complete drive unit ($85) from appliancepartspro.com
May 22, 2008 | Bosch 700 Watts MUM6622 Universal Series...
Bosch mixer doesn't run!
It sounds like the switch to me.mixers last awhile as long as there not overloaded.The brushes in the motor also go bad but i think the switch is your problem.Goto home depot/lowes and take the switch with you,dont forget to mark the wires.If they cant help you goto graingers (its a electrical/plumbing wharehouse).let me know,you can use an universal switch if the one you cant find isnt availiable.
Dec 10, 2007 | Bosch MUM6612 Universal Series Mixer
KitchenAid 32685 Mixer Logo
81 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
