Question about Aiwa HV-MX1 VHS VCR
Picture gets bad after playing a while
My Aiwa-hv mx1u has a problem!
The thing is, I haven't used this vcr for almost 9-years.
Now, when I try to play the tape, it started to play nicely, but after apxm. 40 minutes the picture turned to a many horizontal lines with squeaky sound.
Tape is alright, it didn't stuck in the vcr or anything like that.
I've tried again, but now the play does not start with nice picture at all, but rather with lines with same squeaky sound.
Is this because I haven't used the vcr for so long? Belt, maybe?
Please help!!!
  • Anonymous Nov 14, 2008
    Film has lines in when transfering pal to ntsc sound and voice are ok.
    Heinz & Gerda.
  • dresperry Jan 24, 2009
    playing movie is covered with blank square. What is this? sound is ok.
  • 579 Answers
Just the usual problem of needing the rubber belts replaced.
They last about 6 years normally so you are overdue.
Buy a kit of belts for your model from all kinds of sites on the net and install them yourself if you are handy with delicate mechanisms.
Hope ya fix it!
Posted on Jan 15, 2008
Will Aiwa HV-MX1 Playback Extended Play (EP) Speed?
Probably not then, but you could try a tape recorded at EP.
Jan 05, 2013 | Aiwa HV-MX1 VHS VCR
My HV-MX1U is definitely over 14 years old and was one of the best electronic devices I ever bought. Nothing was ever replaced or fixed in it so, obviously whatever parts like belts or etc need to be...
Probably both. There is a mode or position switch that tells the processor what position the deck is in. If that has failed that could be a cause also 14 years for belts is a very long time. You may find a kit on fleabay but switch wise, I doubt it.
Mar 24, 2017 | Aiwa HV-MX1 VHS VCR
AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Jan 15, 2009 | Aiwa HV-MX1 VHS VCR
Lost manual
how do i unlock the pin code? aiwa fx7500k
Oct 01, 2008 | Aiwa HV-FX7000 VHS VCR
Tape stuck in VCR
more than likely one of the belts has broken
Oct 12, 2007 | Aiwa HV-MX1 VHS VCR
Aiwa vcr HV-FX 7800k
If you are asking 'why ' does this VCR have 2 speeds, it is to help you locate a certain portion of the movie fast. If you are asking 'Does' this VCR have 2 speeds, the answer is YES.
Mar 29, 2007 | Aiwa HV-FX7000 VHS VCR
Aiwa HV-MX100 multiformat VCR won't power on...
Too little information to give any information / help / opinion. What actually happens? Does the Display come on properly? Do you hear any mechanical Noises? Like a motor whirring? Are you able to load a cassette into the machine? Does it get ejected automatically? As you say that the machine switches ON, I assume tyhat the Power supply cicuits are Ok, and this leaves us with the possibility that there is a mechanical problem.Is it that the machine was not used for a long operiod of months or years? If that is the case, in all probability the belts are damaged / broken / loose. I really need more info, please.
Mar 07, 2007 | Aiwa HV-MX100 VHS VCR
Aiwa mx100 (al system vcr)
if your vcr is a multisystem, select the proper system in your vcr for the video to be played. but if not, you cannot play your PAL in your NTSC vcr. good luck!
Feb 25, 2007 | Aiwa HV-MX100 VHS VCR
Our Aiwa MX100 doesn't play our pal system tapes
Just Clean the Video heads with a Wet Type Head Cleaner. Do 2 or 3 runs. Should clear up the problem.
Aiwa HV-MX1 VHS VCR Logo
236 people viewed this question
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
