Question about Sewing Machines
Bernina 730 I have a 30 year old Bernina 730 sewing machine. I need a new slip-on extension table, one with a taper to fit snugly to the body of the machine. Are such part available anywhere? Bryan (office@outbackvoices.com)
  • Anonymous Oct 24, 2008
    I am also looking for an extension table for the older Bernina 730.
I have lost the cord lead to my Bernina 730 sewing machine and cannot get any spares locally. Can anyone out there help find a replacement.
Posted on Feb 04, 2010
  • Sewing Machines Master
  • 12,695 Answers
You can find used replacement extension tables for older Berninas if you are persistent. Some show up from time to time on eBay. Just make sure that it is the correct part for your machine before you purchase.
Another option is ordering an acrylic extension table cut specifically to fit your machine. Depending on the size, you could pay ~$100.
Posted on Feb 23, 2015
Where to buy extension table for bernina 1006
It is an older model, so most likely you will find only used parts. eBay is a place to look, although I can't say I've seen many replacement parts for the 1006. Of course, perhaps the extension table fits more than one machine (although that's not very common with Bernina). You can also check out the acrylic tables (ie Sew Steady) available from several vendors online or even in some stores (you'll probably need to order what you need since they are made to your machine's specifications).
Sew Steady SST Portable Extension Table 11 5 to 32 Wide 15 to 24 Deep 1 4...
Apr 03, 2016 | Bernina Sewing Machines
Will any of the free-arm slide-on extension tables for the other Benina machines fit the Bernette 60?
No bernette is a made for bernina item and will not exchange with bernina
Dec 08, 2014 | Sewing Machines
Bernina 730
try changing the needle--one for the fabric being sewed
also the zig zag could have a worn or damaged gear or cam
or there could be a timing problem.
Apr 11, 2014 | Sewing Machines
Bernina 930 extention table
You can check eBay. Sometimes extension tables are available from machines that are being sold as parts. Be sure that the table will fit your particular machine. There were at least two tables made for the 930 Record, and the tables are not interchangeable.
Mar 04, 2013 | Sewing Machines
As I'm sewing with my Bernetta 730 dog feed
The feed unti dialed inside is seized , you can try removing the freearm plate and adding oil then manual turn the dial back and forth unit the feed dog drop. this will correct the problem for another 30 years
Apr 19, 2010 | Bernina Sewing Machines
My Bernina 730 record can only run the zig-zag stitch. The tech said the motor was "weak". Will replacing the brushes in the motor fix the stitch problem?
Sewing machines needs full service now and then (every 10 years will often do). The motor on the 730 series is actually as powerful as they get on domestic machines, and handles just about everything that fits under the pressure foot. Only if the machine has been used a lot over the years are the brushes worn down, but it might need new grease not matter how little it has been used.
However, the stitch applications can sort of gum or clog up if the machine has not been used for ages. Take a look in the manual and oil ever point suggested every time you take out the machine. Try them now and then on slow speed, that might get every function to run smoothly again.
This is as good a machine as any out there, favorably compared to any new machine under 500£. It sews perfect stitches on just about any material, and is well worth a full professional service (At a shop they will always recommend a new machine they want to sell you). All kinds of pressure feet and accessories are available in regular sewing shops and online.
Check with different shops for price on full service. This is a great machine what ever they tell you.
Nov 20, 2009 | Bernina Bernette 75
Bernina 830 old style need replacment part -under extention table
The clamping yokes for Bernina sewing tables for models 830 and earlier models were hand fitted parts. Welding this may change the geometry so that the table may not fit at all. Additionally the material is diecast AL, not cast iron, and may or may not accept TIG welding applications.
Aug 27, 2009 | Bernina Sewing Machines
Bernina 910 sewing machine extension table
Hi Phoebe,
What you have is the extension table for the 830 and the 830E Bernina models. What you need is part number 301 276 100. This table looks a little different as it has a small see-through window in the bobbin area and also, it has no clamp (it has push-in pins). Ebay or a site like SewItsForSale is your best bet. I doubt the dealer could get one but if they could, it'd be likely around $100.
Jan 17, 2009 | Sewing Machines
Sewing Machines Logo
545 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
