Question about Tomtom ONE GPS Receiver
Tom tom one sd problems
I think i wiped my tom tom ones sd card, cant get anything when turned on! as i just bought it from a friend i have no back up. home page cant find the tom tom when plugged in to usb, also i get the red cross flashing on the unit with orange backgroud.
  • Anonymous Feb 16, 2008
    yes, same problem here.
    dowloaded new updates and now won't work ...red X flasing no matter what I do.
    Please send HELP...SOS
    same problem made a back up and tomtom just flashed red x
  • 515 Answers
I have bought an S.D. Card loaded with Western Europe for my recent trip to England, but when I got there, and loaded the card, it loaded up and went to the front page, and no further, I sought advice from...
So it never work even on a different unit so the problem there can be with the SD card the data inside it might be corrupted, how about if y9ou check the content of that SD card to make sure data are still there...
Hope that helps.........
Sep 18, 2008 | Tomtom GPS
My tomtom will not turn on. I have had it plugged into the car charger for several hours. Help?
try a reset first, i will assume you cant do this, get a clip or pin switch off the unit and remove the sd card, then push the tool into the small reset hole underneath and hold for 15 seconds, then turn your unit back on and replace the sd card, it should then work if not it could be the battery has worn out as they are attached to the charger all the time when driving, hope this helps
Jan 02, 2010 | Tomtom ONE GPS Receiver
I bought the new maps from website, and can not install
If the software crashed whilst updating, you will find that if you try to restore from a complete backup when you switch on next time it will either say you cant use the map or will just freeze, fix re format both the internal memory and the memory card, then find where tom tom home had stored the files, then using windows copy the contents from the 2 folders back into the relitive internal and external card, you will then find that you will get the mesage that you cant use the map, this is because tom tom home doesent always put the map data into the correct folder, to fix this find the licence data and the map data that has been stored on the sd card instead of the internal memory and copy it into the internal memory, before switching off press the reset button, when you switch on you should find that you have a working tom tom
Aug 25, 2009 | Tomtom ONE XL GPS
Frozen screen
I am not fully up on the third edition but lest see if anything else I have might help you out.
I am going to guess you used tom tom home for the update
If you backed up before the accident then there may be a way to get you up again
If you can get (or have) an sd card reader on your computer then put an empty card in there and format it as fat or fat16
Then tell your tom tom home to RESTORE but point it to your blank sd card.
When it has done throw it in the tom tom and power up this has worked on a couple of other model tom toms.
If you don't have a back up then the only other way is to get a working one and back it up on your machine and do the above.
That's a hit and miss approach though
Aug 22, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom one version 3
U don't need a SD card for the unit to operate, it is an optional item..
Aug 14, 2009 | Tomtom ONE GPS Receiver
When i turn on the tom tom one
I saved the map on to my computer from the tom tom in Tom Tom Home and installed it on to a new SD card and now it working perfectly. I bought a 2mb SD card for £6.70 put it into a card reader and connected to computer and installed map and it gave me the instructions to put into device (Tom Tom) and switch on to connect then off and back into card reader to finish. Then I disconnected device which is important to do by the way put the new Sd card into Tom Tom and it is workink perfectly. I hope this help others who have problems.
May 17, 2009 | Tomtom One Europe v2 GPS Receiver
Tom tom sd card wiped clean
more than likely, I just purchased a new tomtom sd card on ebay with all the new maps on it, ver.7 got it for a UK seller no problems, did you back it up on your computer? hopfully you did, then you can just connect it to tomtom home and reinstall it.
Oct 11, 2008 | Tomtom GO 300 GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
100 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
