Question about kawasaki PVS-10921 Portable DVD Player
Invalid disc Unit has been runnning fine then all of a sudden the unit turns on says loading takes 1 minute and comes back with invalid disc? I can here the disc moving and disc works in other dvd players?
    New Friend:
From experience you should never touch the lens . If this is last resort then use a q-tip and 90% rubbing alcohol (or higher%) . If that doesn't work my friend it might be time to throw it away or return it.
Posted on Aug 31, 2015
    Genius:
  • 1,003 Answers
Try to manualy clean laser lens (the little glass looking bubble )with canned air dont touch then wipe the rubber area where disc sits on when a disc is loaded off with windex applied to a microfiber towel then try to use.
Posted on Jan 14, 2008
All my DVDs say "invalid" when I try and play. This just started all of a sudden. Was working just fine before.
Always first unplug for a minute and make sure the discs are VERY CLEAN. Sometimes my player/recorders give an error message 2-3 times but eventually are able to load the disc.
Mar 29, 2014 | Toshiba UNTESTED, AS IS BDX2150KU Blu-Ray...
Sony BDP-BX2 Blu-Ray player now rejects valid discs as "invalid"
Sometimes the latest update IS the problem, not the solution. If possible go back to an earlier version and retry the disks. Many of the answers here about power down and the like are all good and sometimes helpful things to do. They also point to the fact there isn't much a consumer can do to fix or repair malfunctioning DVD/Blu-Ray players and it always comes down to cost. Do you want to repair or replace. You've had your unit, you say, about 3 years? I think this is about end of life. Anyway, try the previous software version and if that works turn automatic update off.
Nov 14, 2013 | Sony BDP-BX2 Blu-Ray Player
Invalid disc
The disc could have the wrong region code
Jan 16, 2013 | Sony DAV-HDX500 System
All of the sudden my printer is telling me that my cartridges are "Invalid"
is you machine hooked up and have internet then it might have gotten new firmware and if you are using generic cartridges this can happen. try oem lexmark cart.
Jul 04, 2017 | Lexmark X2500 All-In-One Printer
Keep getting "Fail" on blank discs
The LVW-5005 DVD Recorder came with a list of recommended brands for each type of disc, and they are all different in all categories. Some brands are recommended for CDs, some for DVDs, etc. They are not the same in any catagory. Most of the ones I bought were not on the list, because I couldn't find those listed anywhere in my neighborhood here in California. Some worked before, but are not working well now. Some have never worked, and some are failing intermittently.
The INVALID DISC message comes up on both units often, but when it comes up on the LVW-5005 unit the DISC eject feature will not eject. The open close door stays shut and says it is open, but sticks and keeps trying to reread the disc. You actually have to tip the machine down to let gravity help, and then turn it on and off and on and off and it finally opens and drops out the invalid disc.
The LVC-9016G unit says "change disc", or gets stuck on "Preparing". Sometimes it prepares, and then I can actually record, but when I try to load it later..... FAIL! This too is INTERMITTENT. GOD I HATE THAT WORD!!!!
I am not good a taking machines apart, and I have a MAC system 10.5 computer, and the firmware update seems to be geared to the WINDOWS PC. HELP?? Is there anything I can do.
Also IS THERE A LIST OF PREFERRED BRANDS of the media for the LVC-9016G model. It may be the same as the list for the LVW-5005 unit, except the that unit is supposed to record on CDs as well. NOT SURE> None are working consistantly.
The other idea that I had is that the newer DVD-R and DVD-RW or the DVD+R and DVD+RW discs have a heavier technology and these older burners (2 years makes it older, I guess....) and seem to no longer like them.
The 6 hour SLP I always set them to record on in the past, may no longer be valid. The 4x, 8X 16X etc. may not work either. Since I don't understand what that means, and we only have access to what is available to buy, I am at a loss there too. I am logical, but not technically educated in this technology. I come at this with psychology, not technology... :-)
I have the LVC-9016G for 2 years, and the other bought at COSTCO only a year ago. Is $300 worth of equipment already obsolete?
I have not hacked or touched anything. I may need to buy another lense cleaning disc. I have a memorex one, but when I put that in it said INVALID DISC, and will not work either. Won't read or spin.
I am frustrated...http://club.cdfreaks.com/images/smilies/6/eek.gif.
Candy user_offline.gif this can be due to invalid media........all types will not burn in this unit........good success....meder's tv service
Nov 28, 2012 | Lite On LVC-9016G DVD Recorder/VCR
Keeps saying 'no disc' or 'invalid disc'
The Laser Pickup Assembly is the problem, the laser eye is weak and can not read the disc. If you take a Q-Tip and rubbing alcohol carefully clean the laser plastic lens allowing several minutes to dry. If after all this there is no change the only option is to replace the entire unit, because the cost of repair would not be justified.
Jan 07, 2011 | RCA DRC6338 Portable DVD Player
Invalid disc reading
reset to factory mode, should be in the instuction manual ,how to do it.
Mar 28, 2008 | Lite On LVC-9016G DVD Recorder/VCR
Invalid Imaging Unit and Toners
Sorry about my last post. I didn't realize that it would be placed unter solutions. BUT I did get a resolution from Samsung. They passed me to the advanced team and they suggested I use a special code they gave me to reset all the machine. As I said before the machine was giving me an error that all the toners and the imaging unit were invalid. Samsung said to try this and if it didn't work they would send me a new (refurb) unit. They said to press in sequence <menu><#><1><9><3><start (b&w)> then when the unit cycles it will ask to imput the country, in my case I entered the US. The machine will then reset itself and all the cartridges and imaging unit should be reset to work. IT WORKED!! The machine said to wait while it re-installs the toners. When it did the red warning light turned off and the printer is working great. Hope this helps.
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Dvd player comes up with pre-stop or invalid key
I would just return it to where you bought it and exchange for working unit. You probably just got a lemon.
Mike
Dec 14, 2007 | Televison & Video
LiteOn LVC - 9016G dvd recorder Problem.
throw it in the trash- I got 1 from costco, liked it so much, bought another a week later. First one started giving me the "invalid" msg, 2nd one did the same 1 wk later, so I guess they're programmed to do so after so many hours after being plugged in. Too bad, cuz it was the easiest to use of 5 previous models I tried. Their easyguide onscreen menu was the greatest, plus the status of time, pause & recording indicator, which you could turn on or off as needed, were very useful.
A real shame to have to throw in the trash. Won't ever buy another thing from them.
Nov 20, 2007 | Lite On LVC-9016G DVD Recorder/VCR
kawasaki PVS-10921 Portable DVD Player Logo
351 people viewed this question
Top kawasaki Televison & Video Experts
wayne chamberlain
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
