Kenmore Washing machine spins slow
Machine washes normally but will not kick into the "fast" spin cycle. It just spins the same "slow" spin it uses during the delicate cycle.
  • 3 more comments
  • Chuckdad Jan 15, 2008
    The washer has 3 wash cycles. With the Heavy and regular cycles it is supposed to spin at a "fast" speed but it only spins at the slower speed which is supposed to be for the "delicate cycle." Therefore it doesn't get the clothes as dry as it should.
    Correct, no "speed selection switch" just the 3 different cycle settings. I'll try the timer. Thanks!
  • Anonymous Mar 25, 2014
    fast spin cycle
  • thesavards Sep 05, 2014
    If the switch is not bad depending on the model underneath towards the back there is an electronic part called the speed board. This could also be the problem.
    http://www.ebay.com/itm/Kenmore-Elite-HE... Here is an example of the speed board. you can look your model number up at www.searspartsdirect.com and that will give you the part numbers. You can then use those numbers to search on ebay. I have gotten a few parts this way makes it a bit more affordable.
  • 447 Answers
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Posted on Jan 15, 2008
  • joey  shearer
    joey shearer Jan 15, 2008
    are you saying that it has no speed selection switch?? If so, then the problem is likely the timer.
My washer is stuck in fast speed. Can't make it agitate in slow speed. Model # 110 26892690 .
I assume you mean spin.You should have a slow/half spin selection on your machine if not select a delicates or wool program this will give you a slow spin.
Feb 24, 2015 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
It spins during rinse cycle but the clothes don't spin dry. Still very wet, even after a second spin without any more water being added.
It may not be spinning fast enough. Is the agitator operating at normal speed?
Possible causes for slow spin are overloaded washer, slipping belt, bad bearings in the motor or clutch, or slipping clutch.
Another possibility is a problem with the pump, but I suppose you would also see some water left in the bottom of the machine in that case.
Dec 05, 2010 | Whirlpool LSQ8543J
Hello The washing machine is not going through
The lid switch has failed. It will not spin because it is a safety device.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 22422 Top Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Machine will not agitate during rinse cycle of normal wash.
The brake is part of the mechanism to function the spinning. The agitation is another mechanism to function in the other direction of the same motor. This mechanism is below of the other. The helix part needs to replace to fix this. This should be done when you change the brake. Of course this is a result from the brake change since you have take this apart before you can get in the spinning mechanism. It is good that now you don't have to touch the spinning mechanism, but only the agitation mechanism. It is not from the tight belt. Hope this can help.
Jan 09, 2010 | Dryers
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washer just fills up and that is it
Sounds like a winding on the motor is burned out or the timer is defective. The motor uses a low power circuit during the delicate cycle both during wash and spin. The timer selects which winding is energized (fast or slow).
Feb 05, 2007 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
786 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
