Question about Philips CDR600 CD Recorder
PHILIPS CDR 600
I CANT OPEN UP THE DECK ON THE PHILIPSCDR 600 THE DECK SAYS DEALERS MODE HOW CAN I FIX THAT?
  • 3 more comments
  • VON DUTCH Jan 15, 2008
    IT DIDNT WORK HAVE ANY OTHER SOLUTIONS?
    that didnTHAT DIDNT WORK IS IT 2 BUTTONS BECAUSE THE DISPLAY BUTTON DIDNT WORK?
  • VON DUTCH Jan 16, 2008
    WHAT IS OPC ERROR AND HOW CAN I FIX THAT I CANT RECORD IM USING A MEMOREX RECORDABLE CD AND ITS ALSO SAYING DISC ERROR WHEN I PRESS TYPE
  • VON DUTCH Jan 18, 2008
    yea its a audio cd do i have to send it to get fix?
  • Anonymous Jan 27, 2008
    When I set the power on it don't say INSERT DISC but close or open but the port isn't opening Find Me A Solution
  • 112 Answers
I think you hold in the 'display' button when the unit's off in standby to remove the dealer lock. It's designed to stop shoppers nicking cd's when the units on display in a shop. If this doesn't work post back and I'll try it on my cdr600.
Posted on Jan 15, 2008
  • fluffy cat Jan 15, 2008
    Hold in the open/close and stop button as you power it on.
  • fluffy cat Jan 16, 2008
    opc error means the laser's not working properly. Are you definatley using an 'audio' cdr?
Philips cdr 820 stuck in finalize mode. it wont finish
Contact any service technician; who have advanced testing equipment [Compair] a must. Never attempt to repair this set by self. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 01, 2016 | Philips Audio Players & Recorders
Phillips cdr 200 recorder, just recorded 13 tracks with time left over on sony brand recordable cds for music. i switched from analog to digital to finalize and it took 4 mins however RECORDABLE still...
It sounds like it didn't truly finalize. Try finalizing it again since the 'recordable' status implies it still qualifies. You have to press RECORD immediately after FINALIZE.
The Philips directory lists a few CDR200 models but the documentation contains directiosn for CDR765.
http://www.p4c.philips.com/files/c/
for example...
http://www.p4c.philips.com/files/c/cdr200bk/cdr200bk_dfu_aen.pdf
If for some reason you ever want or need to extract music from a non-finalized CDR or CDR-W, try loading it into a standard DVD player. Without a TOC the player won't be able to display track info or navigate to individual tracks but it MAY play it straight through anyway and you could digitally capture all or part of the output on another CDR. Just be aware that if the original is rewriteable and has old data beyond the new data you will crash into it without warning at the end of the new data, so be ready to pause your copy at the appropriate time.
Apr 07, 2011 | Philips Audio Players & Recorders
Can i connect my mixer to the input of the cdr 765 then connect the amp to the outputs. Will this work and record?
If you just treat the CDR as a tape deck, I'm pretty sure your mixer has accomodations for that. Then you won't have to connect the amp to the CDR and anything you want to mix/monitor will be available to the amp.
Jan 11, 2011 | Philips CDR765 2-Disc CD Recorder
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Philips 765 CDR - twin deck
Remove the 765's casing. If you don't have a star shapped screwdriver use a flat head which sits tight in the screwheads diagonals. Once removed, observe the 765's driver chip which sits behind the recording deck mechanism of the left hand deck. With the power cord disconected carefully remove this chip by gently working a flathead driver between the chip and it's base (the chip is not soldered to it's base but take care not to bend the pins) Once removed, power up the unit for a few seconds making sure that you do not touch the live internal workings. Remove the power cord again and switch the power button on for a few seconds(with no power chord attached) to allow the units capacitors to discharge fully . Gently replace the driver chip. Replace the cover and switch the unit on again. The unit should reboot and the gremlins should be gone.
Jun 03, 2009 | Philips CDR600 CD Recorder
My CD Recorder is not reading my blank discs. What can be the pro
hi not sure if this helps but some disc ,s ive used on my 500s won,t work either so i changed the type of disc and it seems to do the trick i think some disc,s just aren,t good enough ie cheap ones .
Jan 13, 2009 | Philips CDR600 CD Recorder
Deck A will not play/Deck B OK
Sounds like the CDR deck has an issue. When the disc comes out has it's position changed i.e has it been spun at all? Can you hear any motors moving? Does it work with any type of disc ( cd/cdr/cdrw)?
Feb 14, 2008 | KLH CDR2000 2-Disc CD Recorder
Not reading blank cdr audio disks to record onto..
Will it read audio cd's? Sounds like you need a new laser unless you have access to a philips COMPair system to diagnose / realign it.
Dec 12, 2007 | Philips CDR600 CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Open Questions:
Philips CDR600 CD Recorder Logo
434 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
