Question about Hoover F7220900 SteamVac V2 Upright Vacuum
HOOVER STEAM CLEANER PROBLEM
I CANNOT GET MY SOAP DISPENSER, GRAY PLASTIC PIECE THAT GOES UNDER THE WATER TANK, WHERE EVERYTHING GOES TOGETHER. DON'T KNOW IF THESE ALL SHOULD GO APART BUT SOMEONE TOOK IT APART AND NW I AM BAFFALED AS TO HOW TO PUT IT BACK TOGETHER.
THANK YOU SO MUCH
LOUELLA
[email protected]
  • Anonymous Jun 11, 2008
    cannot get he brushes to work
Haven't used my steam vac in a number of years. Am I supposed to hear steam, floor carpet seems
cold and wet thanks
Posted on Oct 13, 2008
The switch in my hover steam cleaner is broken, how do I repair it
Posted on Feb 15, 2008
    President:
  • 1,673 Answers
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Posted on Jan 15, 2008
6ya staff
SOURCE:
Steam Vac Is Not Dispensing Soap
Try using a rubber tipped air nozzle and compressed air at the end of the soap dispenser line. Brief intermittent blasts of air should take care of it.
Nov 16, 2013 | Hoover F6212-900 / F6215-900 SteamVac...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The clean water tank is leaking terribly
This was a common problem for the models that were manufactured with a two piece tank. These tanks will have a colored soap container attached to a clear water tank. The plastic was too thin around the valves and would crack. You need a new style one piece tank ( # 42272104 ).
Mar 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Flow indicator does not spin when the trigger is depressed like nothing is coming through, pump?
Usually that is showing no soap in soap tank even if there is water in the water tank.After filling soap tank make sure it locks in real good ;Thats been my problem a few times.I didnt know the water and soap were in seperate tanks the first 2 times I used mine lol....
Jun 22, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 9500 ProHeat 2X Clean Shot will not let water put from tank?
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaking Hoover Scrub Spin Carpet Cleaner
A picture would be nice. Be advised that broken plastic is hard to repair.
Aug 05, 2017 | Hoover F5906-900 Upright Steam Vacuum
Leaking
Could be that the despensing tank has melted and deformed at the connection point. This is what happened to me when I put in really hot tap water. The heat allowed the connection (where the water/soap outlet is) to deform when using it. Now when I fill the tank and place it in the machine the water just leaks out all over the place with no control.
If you look at the bottom of your tank, where the water comes out, you may be able to see that the plastic is mis-shaped or deformed slightly. It probably doesn't take much for the seal to be broken.
TEA
Sep 22, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
517 people viewed this question
Top Hoover Vacuums Experts
Kirk Thompson
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
