Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Replaced lower element after short
Still doesn't work. One of the questions on your website indicated that the owner replaced the high limit switch. How is the high limit switch removed? Is it unscrewed? Or pried out?
  • 3 more comments
  • Jerry Goggins Jan 15, 2008
    Model SVE 47500B; S/N 02452563QS
    I called Jenn-Air customer service this morning, only to find that they don't do troubleshooting on the phone. They suggested that I call the local Jenn-Air dealer for service assistance.
  • Jerry Goggins Jan 16, 2008
    Hi, Mike:
    I pulled the stove out and checked the voltages as you've suggested. They all check out, i.e., 240V across L12 and L2 and 120V across L1 and neutral and L2 and neutral. However, the smaller circuit board (or relay board, as you've described it) has obvious burn marks on it so it's probably cooked. I'm trying to get Jenn-Air on the phone but I'm getting a busy signal. I'll let you know how it sorts out, once I secure a replacement board.
    Thanks, Jerry
  • Jerry Goggins Jan 17, 2008
    I was able to order the board from Jenn-Air, which was shipped on Wednesday from St. Louis. It should be here on Friday because I live just outside of Milwaukee, WI. I'll let you know if that fixes the problem.
    I'm pretty confident that the new board will fix the problem; it's very obviously burned, with several wires broken on the board itself.
  • Jerry Goggins Jan 19, 2008
    I replaced the smaller board (fan control)because it was obviously burned. Everything works now (the fan, burners, broiler element) except the oven element. I don't get any voltage when I check the wires to the oven element, so it's obvious that there is something else wrong. Could one of the relays on the main board be bad? If so, can they be replaced?
    The main board is almost certainly several hundred dollars, so I'll replace the range before I spend that much money.
    Please get back to me when you get a chance. Thanks for all of your help so far.
    Jerry
    Scholar:
  • 128 Answers
Call Jenn air customer support. They will be sure to help you. :)
Jenn-Air Customer Service representatives are available by phone Mon - Fri from 8 a.m. to 8 p.m. (Local Market Time) and Sat from 8:30 a.m. to 5 p.m. (Local Market Time). For questions about your Jenn-Air appliance, please locate the appliance's model and serial number before calling: Jenn-Air Customer Service 1-800-Jenn-Air
Posted on Jan 14, 2008
  • 290 Answers
They are generally mounted to the rear of the oven with screws. Not all ovens have them. Please post the complete model number from the range and I will try to help you find the problem.
Thanks/mike
  • 2 more comments
  • Michael  Lindley
    Michael Lindley Jan 15, 2008
    Thanks for the model and serial numbers.
    The Hi-limit switch is in line between the L1 terminal on the power block and the bake and broil elements. If the broil element works, the limit switch is ok.
    You will need to pull the stove out and remove the back panel.
    You will see the terminal block that connects your house wiring to the stove. There should be some black wires coming off one terminal. This is your L1 terminal. There will be a terminal with a red wire. This is your L2. The terminal in the center with white wires is the neutral.
    You should have 240 volts checking across L1 and L2. You should have 120v across L1 and neutral, and 120v across L2 and neutral.
    Power comes off the L1 terminal to the Hi-Limit switch, from the Hi-limit it goes to the oven elements.
    If the broil element works, then you know the Hi-limit is ok and you know the L1 power is ok.
    If the broil works but the bake does not, you either have a burned wire or there is a problem with the control board or relay board.
    The relay board supplies the L2 voltage to the elements when you select bake or broil.
    Check these voltages and post back with what you find.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Jan 17, 2008
    Jerry,
    It probably needs replacing if you see burned spots.
    If you don't have a wiring diagram to help you trace down the wires, go to sears.com, click on parts, and enter your model number. You can click on the diagram under wiring information and then you can tell what wires go where and which board you need. There are 2 boards on the back of your stove I think. One is the main relay board that controls the oven and one is the fan control board. I find it easier to read the diagram if I save it to my computer so that I can control the size on the screen a little better. You can also look up your parts and order them from the sears site, but you may want to check prices different places.
    Mike
  • Michael  Lindley
    Sorry it was so late getting back to you. It was a long day and I didn't get in from work until late. Just logged on the computer at 10:30 cst.
    Mike
  • Michael  Lindley
    Michael Lindley Jan 21, 2008
    The main relay board controls the bake, broil, and convection features. If you have no power from the relay board to the bake element, then you will have to replace the board. It costs around $250.
    Thanks/Mike
Keeps throwing up trouble codes p1506,p1151,p0302,p0171
Definition of Diagnostic Trouble Code P1506 Audi: Closed Throttle Position Switch Does Not Open/Short to Ground BMW: Idle-Speed Control Valve Opening Solenoid Control Circuit Signal High Ford: Idle Air Control Overspeed Error (see P0507) Jaguar: Idle Air Control System RPM Lower Than Expected - B Bank Kia: IAC Valve Opening Coil Voltage High Lincoln: Idle Air Control Overspeed Error (see P0507) Mazda: Idle Air Control Overspeed Error Mercury: Idle Air Control Overspeed Error (see P0507) Porsche: Throttle Jacking Unit Lower Mechanical Stop, Signal Implausible Volkswagen: Closed Throttle Position Switch Does Not Open/Short to Ground Volvo: IAC Valve Opening Signal
Definition of Diagnostic Trouble Code P1151 Audi: Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded BMW: Oxygen Sensor Heater Circuit Signal Intermittent (Bank 2 Sensor 1) Ford: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Jaguar: Lack of H02S-21 switch, sensor indicates lean Land Rover: Lambda control limit bank 2.Implausible signal/condition Lincoln: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Mazda: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Mercury: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Subaru: HO2S-12 Heater Circuit High Input Toyota: Coolant Path Clog Up for Coolant Heat Storage System Volkswagen: Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
Definition of Diagnostic Trouble Code P0302 Category: Powertrain Definition: Cylinder 2 Misfire DetectedNote: This definition of P0302 is applied to all manufacturers
Definition of Diagnostic Trouble Code P0171 Category: Powertrain Definition: System Too Lean Bank 1Note: This definition of P0171 is applied to all manufacturers
Jun 17, 2015 | Cars & Trucks
Dryer runs but doesn't heat.
The high and Low thermostatic limit switches must be in working order for the heating element to get power to operate. High limit opens in the event of a overheat condition to cut off the heating element. The low limit cuts on and off to control normal operation of the heating element for a more or less constant heat for drying.
Mar 18, 2014 | Kenmore Elite HE4 Electric Dryer
Replaced thermal fuse in kitchenaid keys777 eqo dryer if started working then it has blown another thermal fuse .had a spare fuse .what could cause fuses to fail,thanks
There is a high limit and low limit switch also in the circuit. If either of these fail, it can blow the fuse. Also, if your heating element is shorting to ground, it will blow the thermal fuse. It is standard practice to replace the high and low limit switches with the thermal fuse.
Apr 30, 2012 | Dryers
Electric range not heating
You should check your Hi Limit thermal switch part#74008715 you will have to remove the oven from the wall to access this part.
http://www.on-timeappliance.com/ovenrepair.html
Mar 24, 2012 | Amana Kitchen Ranges
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
Where would the fuse be and how hard to get to, is it in the upper unit? From behind? or lower unit? Running but no heat.
The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components.
Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Also bypass the cycling thermostat if the dryer still doesn't heat with the thermal cut-off and the high-limit thermostat bypassed. Check the heating element visually for obvious broken or damaged coil. An ohmmeter will be of great help in checking the resistance/continuity of the heating element. Replace the heating element if broken or damaged, NEVER attempt to repair it.
The problem is likely in the motor centrifugal switch if the dryer still doesn't heat with good heating element and the three components above bypassed. Indicate the exact model number of the dryer should you need further assistance.
Feb 01, 2011 | Dryers
Dryer not working I replaced the Thermal fuse and still not working.
Is the drum turning? If it's turning, then maybe the high-limit thermostat or element is bad. If drum doesn't turn, check lid switch.
Sep 26, 2010 | Kenmore 74672 Gas Dryer
Thermal cut-off blows and high limit thermostat is working with vent clean.Replaced thermal cut-off, high limit thermostat and heating element. Still blows thermal cut-off.
Any time a thermal cut off blows, it's because the cycling thermostat is bad. When it's bad, the machine cycles off of the thermal cut off rather than the cycling thermostat allowing the dryer to over heat. The thermal cut off is a re-setting safety and is not made to cycle off of. The thermostat you are looking for looks like a high limit thermostat but it cuts power to the element at a lower temp. Around 158 degrees + or - 25 degrees. It's located close to the high limit. It's a normally closed switch that opens on the rise and it will show closed now but the problem with it is that will not open. Replace it and your problem will be solved. Good luck.
Oct 16, 2009 | Kenmore Dryers
Limit switch burns out
Bravo on your troubleshooting, however, it is strongly recommended that if the hi-limit thermostat and/or the Thermal cut-out are defective that you replace BOTH components at the same time. That's why they are commonly sold as a set. Failure to do so can result in premature failure of the components you just replaced. In addtion, before you replace any components, make sure the dryer exhaust vent ducting is clear and free of obstructions. This is usally the cause of most dryer failures. This will cause the heating circuits to overheat, which is usually why the TCO or hi-limit thermostats fail. Let me know if you have any questions. I hope this helps you.
May 04, 2009 | Dryers
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
300 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
