Question about Foxconn K7S741GXMG-6L AMD Socket A Athlon/ Duron/ Sempron microATX Motherboard- Retail (0683562741415)
Wiring of the board
I bought a case with the Foxconn K7S741GXMG-6L board in the case but it didn't come with the manual and wasn't wire.
    President:
  • 317 Answers
Hi Expert, I am switching Foxconn 661M03-G-6L from my old PC casing to a new casing but forgot to lable the pin connections for the following: Power Switch, Power LED, HDD LED, Reset Switch and Speakers ...
You need the manual which you can get here for your board, and download it at the bottom of the page, once you have the manual, then you should see the connections. The other way to tell is to look closely on the board, it might say which goes where right by the connection on the board, and then the wires should say on them what they are, and you can put them where the board says, if you have that on your board.
http://www.foxconnsupport.com/download.aspx?models=en-us0000280&category=C000000001&series=en-us0000001&keywords=&sort=Motherboard%20Manual
Dec 01, 2010 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
Motherboard is not powering on and generates heat from the power supply
Sounds like a faulty power supply... Time to replace it! :)
Also, read this tip of mine to find out more possible causes to your probem.
Regards,
Pelu.
Jun 28, 2010 | Foxconn K7S741GXMG-6L Motherboard
FoxConn 661MO3-G-6EL is suuposed to have 2 1394 Firewire ports installed, 1 in the rear panel and 1 accessible on the board from a front bus connector, but mine seems to be msssing these, whcih does not...
Return the motherboard to the place where you bought it, and have them explain the differences that you have observed.
Are there any wires running from the FireWire port on the front of your computer's case to any connector on your motherboard?
May 30, 2009 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
Foxconn K7S741GXMG-6L Integrated Input/Output Port Activation
i have same problem on my motherboard and it is due to damage, check and see if your RJ45 (lan) is disabled in the system bios.then see if you are not drawing more than 500ma on the usb. good luck!
Jul 28, 2008 | Foxconn K7S741GXMG-6L Motherboard
FOXCONN K7S741GXMG-6L
AMD 2800+ is 333MHZ while
AMD DURON 120MHZ is just 200 MHZ
It means that the board supports 333MHZ not 200MHZ.
Well it's not compatible...
Jan 27, 2008 | Foxconn K7S741GXMG-6L Motherboard
Post issue
I can't get Foxconn's website to pull up ATM, but I had this sort of issue once before, and felt completely stupid once I figured it out, and this is going to sound strange, but, remove your CPU fan and try to power up. If it does power up, then your CPU Fan is shorting out the system. If that doesn't fix it, then it is possible that your processor is not supported by the motherboard.
Hope this helps!
-Backu
Jan 15, 2008 | Foxconn K7S741GXMG-6L Socket...
Foxconn K7S741GXMG-6L Sound issues
maybe the problem isn't in the sound cards or buil-in sound cards, i'm sure it's the speaker your are using, it may have some power leakage or something of that sort... check your electric "ground" connection too.
Jan 26, 2007 | Foxconn K7S741GXMG-6L Motherboard
Dead board.
He is refering to this posting: http://www.fixya.com/support/t128900-mobo_no_boot_after_changed_power_supply
Jan 01, 2007 | Foxconn K7S741GXMG-6L Motherboard
Foxconn K7S741GXMG-6L AMD Socket A Athlon/ Duron/ Sempron microATX Motherboard- Retail (0683562741415) Logo
140 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
