Question about Dell 922 All-In-One InkJet Printer
Clean nozzles in printer
I need to know how to blow out or clean the nozzles in the printer.
    Champion:
  • 207 Answers
Click start button of your desktop, go to printers and faxes, right click on your Printer icon then click properties.
Click tools tab, locate the clean ink head (make sure you have a paper on your printer.ok?)
Posted on Jan 14, 2008
My printer does not print clearly, only part of words
Hi Chuck,
The nozzle on your printer cartridges are blocked. You need to run the Cartridge cleaning process. You have not mentioned the Epson model #.
Remove the Cartridges, Gently blow air on the nozzle area.
Regards,
Suhail
May 16, 2012 | Epson Office Equipment & Supplies
I have one side of the wipers spray out fluid, but one side not.
This is called the washer spray nozzle.Did you try removing the hose and then blowing thru it?I always try blowing from the nozzle end back to the washer bottle.If you can remove the hose from the nozzle and blow back towards the washer bottle.If you can blow back to the bottle then you need to replace the nozzle.Hope this helps.Good luck.
Feb 26, 2012 | 2002 Chevrolet Tahoe
Clogged print head
Put the black ink cartrige nozzle in warm water and wait several minutes.I don't know if this will work in your case but you should try it. I had similar situation and this helped.
Dec 15, 2011 | Epson Stylus Pro 4800 InkJet Printer
Printer worked fine until yesterday changed ink cartridges now black wont work tried all options
Hello
well changing the cartridges will not effect anything to the printer but the duration taken for replacement will. As in epson if you leave the printer without cartridges will clog the head nozzles. Did you remove the cartridges and turned off the printer and left idle for sometime? if yes then follow the instructions below
1. Print nozzle check test print to know which nozzles are not working
2. Head cleaning from the printer software.
3. Perform step 1 again to see the difference after cleaning
IF NO
Then you have to take the print head out of the printer and clean the nozzles by using hot water in the Syringe and blowing the derbies out of the nozzles.
Jul 17, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do I print the nozzle check pattern?
Dear Sir,
plz flow this step for solve your probelm
These are the 2 important features for maintenance of your printer.
Nozzle Check
If your printouts are unexpectedly faint or have some missing dots or lines, it means that certain colour ink does not flow out nicely and consistantly. This is when you need to perform a nozzle check. If your nozzle pattern is good, then, your printouts will be good and nice as well. If your nozzle pattern breaks at certain parts, it means you need to clean the print head. Here's how to perform a nozzle check:
1. Click Start
2. Click Control Panel
3. Click Printers and Faxes
4. Right click your printer icon
5. Click Printing Preference
6. Click Maintenance
7. Click Nozzle Check
8. Click Print
9. Click Finish (if the nozzle pattern is perfect) OR
10.Click Clean (if the nozzle pattern breaks at certain places)
The following is the sample of good nozzle pattern and a bad nozzle pattern:
Good nozzle pattern:
Bad nozzle pattern (Head Cleaning needed):
Head Cleaning
Head cleaning is required when the nozzle pattern is not perfect. Usually, this action is needed when you have printed a lot or you have taken out the cartridge for refilling or for other purposes. Here's how to perform a head cleaning:
1. Click Start
7. Click Head Cleaning
8. Click Start
9. Click Print Nozzle Patterns (to check the ink flow after cleaning)
Thanks For Your Time,
Apr 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Suddenly stopped printing in black though colour is OK.I've tried all the usual things!
the ink head is probably jammed with dry ink. wihen the head is jammed, a lot of ink will pool at the bottom right of the printer. clean that pool, and dab the black ink head with a damp paper towel, but do not rub. blow the ink head with a can of compressed air. run a nozzle cleaning, and nozzle check until the printer is printing better. the nozzle check prints out grid for each color. if the grid is complete the printer is fine. sometimes a few horizontal bars will be missing and cannot be cleaned.
Nov 17, 2009 | HP Photosmart 2575 All-In-One InkJet...
Printer does not print magenta and cyan. Change
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Nov 12, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printer head removal
Hi Kenno23 - have you tried a standard head cleaning cycle and nozzle check? If so,what was the result. If not, try it. If you don't know how to, simply right-click the printer icon in the bottom right-hand corner of the screen, and select "Head Clean". After this has finished select "Nozzle Check". Let me know how you get on, or if you've tried all this with no success, let me know exactly what you have tried.
Jan 09, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson c62 print head clogged
The first thing is that you need to get some compressed clean air and blow all that mess up. There is compressed clean air that comes in a can kinda like wd-40 with a small straw. You can buy it at Radio Shack or some electronic supply place. That will do the trick. God Bless.
Dec 27, 2008 | Epson Stylus C86 InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
105 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
