Question about Routers
Router hi, i have recentle bought a philips wireless router i installed it and everything was fine then my children was cleaning up and accidently threw it away. Now i had a problem with my computer and had to delete everything on it and wiped the installation of. and now i cant find the cd ... is there a website i can find it on so i can download it and gt my router up and running again it would be greatfull xxx
  • 77 Answers
Re: router
You should be able to download the software from the manufacturer's web site, probably by following their support link.
Posted on Jan 19, 2008
0 characters
3 Points
Hi. I have old but stiil good MSI RG54GS2 router. I've bought a new TV Philips with possibility to access to internet and home network. Using LAN cable there's no problem to connect but when I try to...
hi , Check whether your computer has N wireless or G wireless (could be G+N) is yes then also check whether is set to G mode - check the router is also set to G (N will be good if your router support ), check the channel on router (1,6 or 11) .
Main to check - everything will work only if and if you are able to see the wireless signals on your TV . If you are able to see the w/l network then try to connect with right password (network key if w/l is secure). if you are able to see the network key and not able to connect the above can help . More info like error message will help in sorting out the issue .
Oct 01, 2010 | MSI RG54GS Wireless Router
My computers stopped detecting the wireless network. The wireless router used to work fine with all my computers, but today it stopped. I am unable to connect online via wireless, but if i plug cables...
Power cycle all devices. that should do the trick. You may also want to get to the User Interface of the router to check if the router radio has been turned off by accident or the wireless detection has been stopped by accident.
Jul 07, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Can connect computer to internet through modem but not modem-router-computer. Everything worked fine until I accidently unplugged and reset the router the other day. My computer can connect to my wireless...
Use the reset button on the back panel of the router. You will need a pen or toothpick to press the reset button. Once you reset the router, then configure the router as if new.
Dec 10, 2009 | Linksys Wireless-G WRT54G Router
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Nov 22, 2009 | D-Link DIR-615 Wireless Router
Belkin Wireless G Model F5D7230-4 Serial #2007050902D
The how to is in the users manual and its not nice, you have to reset to the default settings.
you can download the manuals & Additional Resources
here >
Best regards
Aug 31, 2008 | Belkin (F5D7231-4) Wireless Router
No internet Connection
this is something simple
2 things you will have to do
the router when a problem like this happens again
unplug router for 1 minute this is packet build up and then plug back in i found this out by service provider that its a build up of packets it relieves packets
now the other thing since you went threw all the little areas of trying to reset modem go in remove your network connection
delete it and build a new network connection threw the network setup wizard then your done restart comp everything should be back to normal and you wont have to ever reset network settings again
just unplug the router let sit for minute and plug back in
Jun 01, 2008 | D-Link AirPlus DI-524 Wireless Router
Dynex Wireless Enhanced G Router -- Lost Password
You'll need to login to the router and reset the wireless key.
May 30, 2008 | Routers
Broadband router range
If you have wireless N router. You should install wireless N adapter on your children's computers as well. That way, they are compatible with each other coz I guess your children's PC has wireless G adapters. You wont be able to utilize the N signal of the router if your using wireless adapters..
May 15, 2008 | Routers
Belkin f5d7632uk4a v4
hi dear
1. Try and uninstall the Belkin client software
2. Check to see if the WZCSVC service is running
You can check this by issuing the following command:
a) net start
b) sc query wzcsvc
Both command should list some info about WZCSVC (Wireless Zero
Configuration) if it is running.
3. If your wireless card is installed successfully, you should see a
antenna-type icon in the system tray.
If not, you need to install the drivers for the card manually. Check
the Belkin CD for drivers.
4. If you can see your new router's SSID (wireless name) then you should be
able to see it as a non-admin as well.
5. Failing all of this, retry the Belkin client software and its
documentation for indication on non-admin issues or ways to use the above
mentioned Windows wireless client.
Mar 18, 2008 | Belkin (F5D7231-4) Wireless Router
Routers Logo
93 people viewed this question
Top Routers Experts
 C. Dante
C. Dante
Are you a Router Expert? Answer questions, earn points and help others
