Question about Microsoft Office Standard for PC
Outlook xp keeps shutting down
Hi i am using xp and my outlook keeps shutting down due to some dll files. i did dected and repair still same issue. i looked the error and tells me about runnig out memory????
    Problem Solver:
  • 13 Answers
The first thing I would check is your current disk space on your main drive, C:\ I assume. Many times I get that error when in reality it's the total disk space that is the problem.
If that is not the problem and you have at least a few gigs (if not, hopefully, much more) free still, check what's running. Do you by chance have an add-in to Outlook that is causing an issue? You can check and try to disable your add-ins by going (in your Inbox) to Tools > Options > Other (tab) > Advanced Options > Add In Manager and also COM Add Ins. Look for non-Microsoft add-ins.
You can disable things from here and see if that helps. If you can tell the exact error message that it gives you and/or the DLL file that is causing trouble, that may lead to a more definite solution. You can also try starting Outlook in Safe Mode by going to Start > Run > and type (without quotes) "outlook.exe /safe" and click OK. See if your problem still happens in safe mode and we can troubleshoot more from there if it is not fixed by this point.
Posted on Jan 16, 2008
How do I get my original inbox back?
You can use DBX Repair Kit. Outlook Express inbox.dbx repair tool fixing of DBX file corruption. DBX Repair Kit helps to repair DBX file of Outlook Express.
For more:
Nov 02, 2015 | Microsoft Outlook Express
How fo I fix Outlook issues after running HP system recovery?
Was it this article that led you to rename extend.dat? Did you do the registry updates, too?
When uninstalling 2003 may have been better if you used windows installer cleanup utility as an uninstall of 2003 still leave behind registry entries.
Uinstall Office again using the cleanup utility, and reinstall.
But first try to restore pst file using Recovery Toolbox for Outlook
and keep it.
Sep 17, 2015 | Microsoft Office Outlook 2003 for PC
I keep getting the message The data file 'personal folders' was not closed properly when I open Outlook, how can I prevent this from happening?
The underlying reason why Outlook displays this "data file" check is very simple. There is a single flag in the header of the data file that is a Boolean value (True or False). While you use Outlook the value of this flag is constantly changing as the data file is updated. When the update begins the value is changed to False and then when the update completes the value is changed back to True (implying the update is finished and successful).
So, the key to the problem is the shut down process because once the Outlook.exe process is exited this flag value cannot be changed. If the Outlook.exe process was terminated prematurely or a 3rd party add-in did not properly set the flag value to True then the flag value can be left at False. If you start Outlook with a data file where the value of the flag is False you are guaranteed to see the "data file" check. If the value of the flag is True then you will not see the "data file" check.
Right now, there are a few known common causes for this issue:
- Shutting down Windows before the Outlook.exe process has exited
- 3rd party add-ins improperly "closing" the data file
- Outlook crashing
- Non-Outlook process accessing the data file
Regarding the post advised by Rod, I would like to explain more detailed:
When you shut down Outlook, the Outlook window goes away, but the Outlook.exe process can continue to run for some time. That's why you can see Outlook.exe sitting in Task Manager for a few minutes after closing the Outlook window. If you shut down Windows while the Outlook.exe process is still running Windows will not wait for the Outlook.exe process to exit. So, you increase the likelihood of encountering the "data file check" issue the next time you start Outlook (because the Outlook.exe process was not able to "close" your data file(s) completely before Windows was shut down).
On the other hand, if you leave Outlook running when you shut down Windows the Outlook.exe process will continue to run and exit on its own. When Windows is shut down, it sends messages to all visible window frames telling them to quit, and will wait for those programs to quit before shutting down. Not until all processes with open windows have exited will Windows finally shut down. This is somewhat counter-intuitive to most people as traditional training has always advised manually closing applications before shutting down Windows.
Mar 10, 2011 | Microsoft Computers & Internet
Outlook express & internet exlorer 7 is not working properly, some dll files are found missing such as regsvr32 mshtml.dll & regsvr32 msjava.dll
Run CCleaner. This is a safe freeware that optimizes the performance of the system, cleans and repairs registries and deletes unwanted files.
All the best!
Nov 17, 2010 | Microsoft Update for Outlook Express 6.0...
Spell check in Outlook Express stopped working. I have repaired Win XP pro from the original disc and reinstalled SP3 and all updates. I repaired MS Office 2010 because spell check won't work without MS...
Here try these steps. Broken SpellChecker in XP Outlook Express
  • Open your Windows Explorer and navigate to C:\Program Files\Common Files\Microsoft Shared\Proof
  • Delete the CSAPI3T1.DLL file if it is present. If it's missing just proceed to the next step.
  • Insert the Windows XP CD and close the window that opens if AutoRun is enabled.
  • Click Start | Run and in the Open: box type msconfig and click OK (See Fig. 01)
Fig. 01
  • Click the Expand File... button to open the Expand One File from Installation Source window. (See Fig. 02)
Fig. 02
  • Make the following entries in the Expand One File from Installation Source window.
  • File to Restore: Enter CSAPI3T1.DLL
    [Note: This entry must be hand typed rather than using the Browse File... button]
  • Restore From: Enter G:\i386\CSAPI3T1.DL_ (Change the G in G:\ to the letter of your CD Drive)
    [Note: This entry must be hand typed rather than using the Browse From... button]
  • Save File In: Enter C:\Program Files\Common Files\Microsoft Shared\Proof
    [Note: This entry can be made by using the Browse To... button]
  • Click the Expand button. There will be no outward indication that the procedure was successful. The Expand One File from Installation Source window will close and you'll be returned to the System Configuration Utility window. Click OK to close System Configuration Utility.
If you prefer not to expand the file from your own XP CD or can't get the procedure to work properly;
Download Expanded CSAPI3T1.DLL File
directly into C:\Program Files\Common Files\Microsoft Shared\Proof
  • Open Windows Explorer and again navigate to C:\Program Files\Common Files\Microsoft Shared\Proof
  • Find the file that was expanded, CSAPI3T1.DL_ , and rename it to CSAPI3T1.DLL
  • Launch Outlook Express and navigate to Tools | Options | Spelling tab. Ensure there is a checkmark next to the Always Check Spelling Before Sending option.
  • Reboot the system and check OE for proper spell checking functions.
Aug 27, 2010 | Microsoft Computers & Internet
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Missing RtlGina2.dll I cant open the OS under any mode, the closest i get is using command prompt which brings up the log in window, unfortunately it wont accept my password, i cant even write in it.Any...
you will need to boot from the windows disc and enter repair mode then copy the missing file. if it doesnt resolve the issue, OS needs to be reinstalled. hope it'll help. =)
Dec 03, 2009 | Dell Dimension 2400 PC Desktop
Unable to open links from Outlook
When clicking a link in the Outlook Express or Word software in the Windows XP Operating System and nothing happens, ensure that the Internet Explorer web browser is set as the default web browser.
1. In the Internet Explorer window, on the toolbar, click Tools and then click Internet Options.
2. In the Internet Options window, click the Programs tab.
3. On the Program tab, click to select the Internet Explorer should check to see if it is the default browser box.
4. Click the OK button.
If the issue persists, follow this procedure:
NOTE: This is an issue which may be resolved by following this Microsoft KB Article: Microsoft KB Article ID 823301.
  1. Click the Start button, then click Run.
  2. In the Run window, next to Open, type regsvr32 urlmon.dll.
  3. Press the ENTER key.
  4. In the RegSrv32 dialog box, click the OK button.
  5. Repeat this procedure for each of the following files, substituting the file name typed next to Open in step 2 for each of the files listed below:
  • regsvr32 mshtml.dll
  • regsvr32 shdocvw.dll
  • regsvr32 browseui.dll
  • regsvr32 msjava.dll
This should resolve the issue.
Good Luck!!!!!!!!!!!!!!
Nov 09, 2009 | Microsoft Windows XP Home Edition
Pc hangs during shut down
As far as Free Antivirus is concerned, you can download Avira from It has the highest detection rates & also extremely light on the system.
May 06, 2009 | Computers & Internet
Communication failure with Outlook when Hotsync-ing Visor Neo
As per your info, it seems that some system file got corrupted / deleted from your system(as .mspst.dll). So request you to reinstall your outlook / XP.
As you can also take some help from below link to resolve the issue by following some defined steps.
+91 9873412111
Sep 11, 2005 | Handspring Visor Neo Handheld
Microsoft Office Standard for PC Logo
322 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
