Question about Samsung ML 2010 Laser Printer
USB not online?
Everytime I try to print, it says USB not plugged in or something of that sort. I try what they suggest: turning off printer, re-plugging in USB, then turning printer back on. The message keeps coming back.
  • 55 Answers
U first uninstall driver,after installing restart the computer after that connect the printer again,n see does it informs that new hardware found n shows the printer name on the screen,if yes then insatll the driver again
Posted on Jan 23, 2008
When i print something the printer acts as if its printing something but the paper ends up completely blank
For a start, here is the manual online you can download if you would need to or do not have one.
http://www.retrevo.com/d/ds/progress?doc=57b90255a3effa7517d400841a329ae7&rk=0.7564768900865393
I read through the Troubleshooting section and did not see anything that was directly related to that particular problem. So I am going to suggest a few options to try out and hopefully this will correct your problem.
1) Turn off your printer and double check all your connections you may be using, USB or Ethernet cable, make sure they are properly connected and there are no problems with the wires themselves.
2) Turn your printer back on and verify that it is connected to you computer, and try to print out a test page
3) Double check your printer cartridges and make sure they are properly seated in place and that they are indeed full!
From there try and print something, be it a text document or something of that nature, and by now you should hopefully have something printed on your page
Sep 15, 2011 | Kodak ESP 5 Printer
I seem to have lost communication with my printer. It will not print. The ppwer button keeps flashing on and off. I have followed all of the troubleshooting guide suggestions. I have checked all cables,...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
Everytime i go to print something it says "printer not responding" the status shows online, and turned on. I put the disc in again to try to install it and it dont even pop up on the computer?
If your printer fails to respond to a job, check that all printer cables are connected properly and be sure that the printer is turned on. If everything is connected properly and powered up, go to the computer's "control panel" from the "start" menu. Choose "printers" and be sure that your printer is selected as the default. If everything checks out in the control panel, right click on your printer icon and select "properties." Click on the "details" or "port" tab and make sure that the correct port is checked off. Next, double click on the printer icon, which will bring up a list of current jobs in the print queue. Cancel all documents and try printing again. If your printer is attached by USB port, you may try connecting to other USB ports.
Good luck, KoBaC
May 22, 2011 | Computers & Internet
I keep getting the message that my canon mp360 is off-line when I attempt to print.
This could be a couple of things but this is the quickest easiest fix so we will try this first go to start then go to your control panel go to printers and faxes once there you should see your printer name right click on it and make sure that it says use printer offline in the drop down menu if it says use printer online left click on use printer online and that will most likely fix your problem if you have done this step and still having problems turn your volume up a little unplug your printers usb cable you should hear some dings if not its ok now Plug your USB back into your computer wait a couple of seconds you should hear some dings try printing something se if it works (you may or may not hear dings depending on your volume settings) if it's not printing or dinging take the usb plug back out the back of your computer and try another usb port if you still hear no dings and it's still not printing switch usb cords it is likely that the cord is bad
Nov 21, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
Problem with the USB port
Don't worry about the toner -it's gonna be more costly to replace your PC if you keep using this printer. i don't know the cause , but obviously if it has happened on multiple computers, there is some sort of short or something going on. Besides, a new printer these days (get your self an HP) is only about the price of a toner cartridge anyway - $100 +/-
Mar 25, 2009 | Brother HL 2140 Laser Printer
Printer wont print!!
Has it printed correctly before?
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 03, 2009 | Brother Multi-Function Center MFC-240C...
Prints test copy everytime I turn unit on
hi,
this is because you have not completed the alignment yet
> unplug the usb cable from the printer
> turn off the printer and turn it on
> let it print the test page
> after that keep the test page facing down on the scanner glass and press the scan button on the printer
> you will see the light on the printer flashing
> wait for a minute
> then plug the usb cable back to the printer
> thats it!!!
> check whether you have the same problem
thanks and regards
agnel
Mar 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Must Reinstall to Print
Most USB printers need to have the printer driver installed before you connect the printer to the computer, did you install the printer this way?
Also, check and see if it is the default printer.
If those do not work:
1) Turn off the Terminate and Stay Resident programs MSCONFIG in VISTA.
2) Disable HP device discovery service.
3) Uninstall the All-In-One software.
4) Turn off firewall and antivirus.
5) Reinstall the latest software for the All-In-One.
Hope this helps.
Please let me know how this works for you.
Jan 30, 2008 | HP DeskJet F380 All-In-One Printer
Printer
Check cable is secure from pc to printer
Check printer can print a status page via printer keypad and is online/ready
If these are ok then it is a print driver issue
Turn off printer, Unplug usb, delete and reinstall print driver
Jan 11, 2008 | Kyocera FS-C5030N Led Printer
Samsung ML 2010 Laser Printer Logo
43 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
