Question about Lexmark P4350 All-In-One InkJet Printer
Carrier jam Lexmark 4300
I get an error message to clear carrier jam - but it isn't jammed. When I try to print something the carrier zooms accross from the right, smashes into the left hand side hard enough to move the wole printer by about a centimetre - then it immediately zooms across to the right again crashing into the side with a loud bang and at great force. When I open the cover the cartiridge carrier does not come out into the middle - I have to pull it out to check the cartridges. I can't print anything. Ive cleaned all the contacts etc. what can I do the printer is only six months old.
  • 6 more comments
  • LaBon72 Jan 21, 2008
    I too am having that problem. Any solutions would be great. My "All-In-One" is not that old either.
    Thank you
  • gitzz57 Jan 25, 2008
    exactly the same problem today and i had my lex for over a year .
  • BOOJACK Feb 17, 2008
    THE EXACT SAME THING HAS HAPPENED TO MINES AND IT'S ONLY ABOUT SIX MONTHS OLD.
  • Anonymous Apr 22, 2008
    Mines 7 months old. Same problem. It smashes itself from side to side. I found a detached spring. Could this be the problem?
  • Beverly Riley Apr 28, 2008
    I'm having the same exact problem as Jonny56's. Please email me whenever, this problem has been solved! I have had my printer for about 1.5 years. My email address is briley9147@sbcglobal.net.
  • mspecantan9 Sep 13, 2008
    I have the exact problem and I have tried cleaning the cartridges with no success. If anyone has found an alternative solution please email me @ mspecantan9@aol.com
  • Anonymous Jan 06, 2009
    where is that small tab?? i don't understand!!
  • steven747 Feb 18, 2009
    i have the same problem with mine its only a month old and the cartrige smashes from side to side as if its trying to break its self what kinda thing is this lol.
I had this same problem, I found a long skinny thin plastic strip had fallen off & caused the problem for me. The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging! Sorry my tech. terminology isn't good, I am not Knowelegable with this sort of thing, just sharing my experience :) HTH!
Posted on Nov 14, 2008
  • jlandry756 Jan 03, 2011
    awesome thanks jj
  • phendrena Apr 27, 2011
    Cripes that really fiddly to do, the plastic strip was loose on mine so tried to put it back. Appeared to have done it but it came off again when i powered the printer back up. Might need to get a new one!!
    Thanks for the solution.
    Genius:
  • 1,554 Answers
On the bottom of the ink cartridge carrier (under the metal bar) is a small tab that must be present to interrupt a light sensor,
you should see it enter this small square sensor . that keeps the carrier synced.
Perhaps this is broken off or the sensor is dirty/bad.
if not broken.
insert a flattened q-tip with cleaner into the sensor to clean.
if it comes out with ink on it keep cleaning it.
Posted on Jan 26, 2008
    Problem Solver:
What is the next best solution if, Coldcut solution does not
work? Should i just invest into a new printer or will Lexmark
replace the part that is defective. I have had printers that lasted
longer. I have only purchased Lexmark printers. Please advise!
Posted on Apr 28, 2008
My printer keeps showing an error message that says 1203. Then it says to consult my user guide. All that is fine except the user guide doesn't have error codes! It also says that the color cartridge isn't in there when it is...i've tried everything! Please help me!
Posted on Aug 04, 2008
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
Carrier jam on lexmark x5070 how do I fix it or clear it?
We apologize for the inconvenience. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover to access the cartridge area. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  2. Remove both cartridges from the printer.
  3. Check the cartridge area and make sure encoder strip is not loose. The encoder strip is transparent strip located behind the cartridge carrier along with the carrier belt.
  4. If encoder strip is properly seated in the printer, close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, re-insert one cartridge first. Close the printer cover and check for any errors. The carrier jam could be due to one of the cartridges.
  7. If no error appears, re-insert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, try to print again to verify that the carrier jam issue is fixed.
We hope this information has been helpful.
Oct 11, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Error message on printer: It says to clear the carrier jam; what is a carrier jam? How do I clear it?
Make sure the paper is out where it was jammed. Unplug the printer from the wall for thirty seconds and plug it back in.
Aug 30, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Apr 15, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Carrier jam
From what you are saying you are getting 'clear carrier jam' because of a misalignment. The jam error message is a generic message that applies to a multitude of things. The carrier while is in right, might not be sitting right. A piece of plastic that holds the carrier might be broken or the printhead might be messed up. Anything that causes it to not sit the way it wants will cause that error message.
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
Carrier jam
your encoder strip(a transprent strip behind the carriage) is either broken or loosed up and so it is not able to get self aligned.kindly fit the encoder properly or change the encoder if neccessary.encoders are usually very cheap.wish u luck!!
Apr 28, 2008 | Lexmark P4350 All-In-One InkJet Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
2,859 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
