Back to:
Tags:
Vacuums
Generic problem for all Vacuums
How do I replace the
posted by coniprovine on Jan 14, 2008
How do I replace the belt on my Hoover self propelled vacuum
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 15, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1210 votes
Turn the vac over, remove the plate covering the brush roll, then you can get to the belt and brush roll. Depending on which model you have, there should be 4 screws, or if it is an older one, there may be 2 clips to unhook the bottom plate.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on How do I replace the:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Kirby Ultimate G Bagged Upright Vacuum
My G4 upright model has no suction when the main front...
Bissell 1697-7 Powersteamer Pro Deluxe...
I have no booklet and steamer does not put out enought...
Vacuums
vax overheating
Electrolux Central Vacuum
Our hose is clogged with a paper towel just behind the...
Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac deluxe spinscub model # F5866-900 how do i...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
