Question about Brother MFC 210C All-In-One InkJet Printer
LCD problem Fax light on all the time and nothing else happening. Jackie
  • jacman Jan 15, 2008
    Thank you for the very quick reply , I followed the solution and it worked. What a great website, I hope I won't be back, but am very grateful for the help!!! JM
  • 832 Answers
Unplug from power outlet. wait 2 minutes. plug to power again. should work. If not there is a defective main circuit board which has to be replaced (costs more than a new mfc at sale!)
Posted on Jan 15, 2008
6ya staff
SOURCE:
Hello! How to program automatic reception of a fax after 4 calls (at the weekends, when at office anybody isn't present. Thank you. Best regards, Veronika
hi; Receiving Both Documents and Telephone Calls Automatically: Fax/Tel Mode If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings: ??? Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting). ??? Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting). ??? Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting). 1 Press [Menu]. 2 Use [{] or [}] to select <DATA REGSTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>. 3 Use [{] or [}] to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>. 4 Use [{] or [}] to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>. 5 Press [Start/Copy]. 6 Use the numeric buttons, or [{] or [}] to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. 7 Use the numeric buttons, or [{] or [}] to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>. Note ??? If paper jams, see "Troubleshooting" on page 53. ??? If the Ink Lamp lights up faxes will be received to memory. 8SEC. 22SEC. Use [{] or [}] to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6. 9 Press [Stop]. Setting ends and the fax returns to standby mode.
Oct 14, 2010 | Canon FAX-JX200
I update status, hit share and nothing happens.
my friend jackie of [email protected]
we tryed asking facebook to send new password jackie was hoping to use snoopy12345 as the pass word. we also try open new facebook which it did not work jackie and have leaning diffictiuty
from [email protected] i and jackie would be greatfull if you could fix it be cause she want to peay on farmville
from
peter abson
Oct 10, 2009 | Facebook Computers & Internet
C514 STOPS mid cycle
I'm having the same problem. It's new and it did it with the first wash. Can anyone help.
jackie
Jul 15, 2009 | Candy CNW136 Front Load Washer/Dryer
Panafax UF-895 - keyboard dead
cracked keyboard from a heavy hand. Will need a tech to replace.
May 05, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Can't get to print out from computer to printer
I got my situation solved with the printer. I was talked thru it step by step. Thank you a lot for all the help.
Jackie
Have a Happy Thanksgiving
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
"line in use" lcd display
here is link
http://slayo.com/resetting-error-e27-waste-ink-absorber-full-canon-pixma-mp150mp160.html
you will need to do no3
EEPROM reset
Just follow instructions!
Checked by me and its working
Marko - SERBIA
Sep 11, 2008 | Canon FAX-JX200
Machine sleeping even when re-powered on
Hi try changing the fuse in the plug first. Once you have done this then power in and open the cartridge cover and press the cartridge button. If the cartridge moves then the LCD has blown and will need replacing if nothing happens then unfortunately the power supply board has blown then replacing the whole machine is the cheapest option.
Thanks J
Nov 22, 2007 | Samsung SF-330 Plain Paper Inkjet Fax
Brother MFC 210C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
