I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP'). 2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
lg 9100 keybo i cant figure out a symbol showing on my phone , its in between the sd card symbol and the music symbol. it looks like 2 texts symbols, but there not. almost looks like a letter on top of another
It's probably the alarm clock, just go into tools, go down to where it says "alarm clock" click what shows up then press edit, then use the left and right arrow keys until you see "off" then press the okay button to save it.
you have 2 buttons one pops out for adjustment the other is only a push button push the left hand one repeatedly till a red clock symbol shows at top of clock then turn right hand knob to set time wait a few seconds and clock will set itself.
the multi-center display (clock, radio display) is on the cigarette lighter circuit i believe it is fuse 12 in the fuse panel on the left side of dash by the door.
I just looked at an 05 taurus it looks like a screw sticking out the side of car? It is the check gas cap symbol.Your gas cap is loose or you have an evap system leak
