Question about Mitsubishi WS-65711 65" Rear Projection Television
Mitsubishi 65711 Trouble
Our Tv wont turn on buy the remote or the button there is a light that flashes under the word timer but it flashes really quick, We have waited for it to stop flashing and tried to turn it on but it wouldnt. We have unplugged it and did the same thing. We also tried the rest button but again nothing What can we do?
  • 2 more comments
  • BlueEyes1279 Jan 14, 2008
    reset button I mean
  • aceshandyman Nov 04, 2008
    Have a Mitsubishi WS-65711 65 in. Rear Projection Television and replaced the 7 capacitors and blinking light went off and tv will still not turn on. Help-
    Do I need a new DM Board and where can I get a new one???
  • Verna_Sandpe Jan 04, 2009
    Blinking green light, no power. Reset, unplugged, Moved from one room to another & problem started. HELP.
  • Anonymous Apr 18, 2009
    Where can I buy DM-0300 BOARD? I think it is the problem.
    Problem Solver:
  • 4 Answers
Try this and see what happens....
Remove the front trim plate below the manual switches, may have to remove the speaker covers to access this area, remove the switch mounting plate 3 screws, turn switches over and unplug the little white electrical connection for the switches. TV should work perfect with the remote now. Not sure what is wrong with the switches just yet, but suspect a resistor problem.
Posted on May 18, 2009
    President:
  • 4,402 Answers
Http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on Jan 14, 2008
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tip
Reset Mitsubishi WS-65711 VChip Password
Bypass or Reset Mitsubishi WS-65711 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65711 Manual Download
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 | Televison & Video
Tip
Bypass Mitsubishi WS-65711 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
I have a WS-65711 Mitsubishi rear projection the power went out last nite and now it wont turn on and the yellow light just keep flashing and when i reset it the light just keeps flashing
you need to buy a new tv when your power went out it was fine when it came back on it surged and fried components in the tv same thing happend to me but i lost my computer vcr tv dvd player and monotor
Jul 04, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green Light Under Timer Stays Flashing and Will Not Go Out
Mitsubishi has repaired some sets if you have the origional purcahes documents. If not you can get the v26 DLP DM repair kit which should take care of that issue. Heres a link to the kit if needed.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Apr 21, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Tip
I hope that helps.
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Tip
I hope that helps.
Mitsubishi 52" WD52725 flashing green timer light
your projector bulb went out. you need to call the manufacturer and order a new bulb. they cost 300 to 400 dollars a piece I believe your tv only has one bulb and they are really easy to install.
hope this helped
please rate well.
Mar 06, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Mitsubishi WS-65711 65" Rear Projection Television Logo
302 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
