Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
Blue glow from everything blue
I have a philips 51" tv and the problem i am having is that the tv has a pretty picture, but the images on the screen that are blue have a blue glow around them or you can say they are extra bright. Has anybody seen this problem before and what could it possibly be?
  • Cary Farah
    Cary Farah May 11, 2010
    have you done focus and convergence from the menu?
    President:
  • 4,402 Answers
Sounds like convergence ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 15, 2008
Yes convergence but there was no focus
6ya staff
SOURCE:
Picture has red and blue shadow images
thats a fairly easy fix. You need the DPTV305-DPTV345 convergence repair kit available at the following link.
http://servicemanuals.vstore.ca/
The kit contains the parts and the CD with instructions
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a glow or a shadow around everything I watch...I tried the converse blue but i dont know if i did it right bc it didnt work...how can I fix that?
CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 17, 2009 | Philips 50P8341 50" Rear Projection...
Bad color 51" projection philips hdtv
need to cahnge the coolant in the Blue CRT thats a very common problem with phillips in the blue and green CRTs
Mar 15, 2009 | Philips 51PP9910 51" Rear Projection HDTV
Blue Glow
Chad, sounds like "FROGGY" coolant to me, Philips brand tv`s are infamous for this problem usually the green & blue tubes, you can confirm this by removing the back cover (carefully it`s heavy and has a large mirror attatched to the inside) turning tv on and look directly into the red lens, you will see a clear image, now look into green & blue and there probably very cloudy. Bad news is this is a very long, dirty, job and very diffiicult for a layperson, if you want to attempt it you MUST buy the service manual (any tv shop can order it for you) I would also advise you to NOT buy philips fluid as the **** they sell will become cloudy again (I use RCA cause it works and it`s cheap) good luck if you attempt it, I would advise you to calll a tech, video-tek
Feb 07, 2009 | Philips 9P5531C TV
Phillips 51pw936317f picture not as sharp as when new
Jan 17, 2009 | Philips 51PW9363 51" Rear Projection...
Double and curved image on blue warm-up screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2008 | Philips 51PP9910 51" Rear Projection HDTV
Philips big screen projection tv
sounds like the Convergence ICs are getting ready to go. Does it appear as a outline almost 3D? If so its convergence if its more like a glowing halo its coolant in the blue CRT that needs changing.
Jun 20, 2008 | Philips 51PW9363 51" Rear Projection...
Picture and screen
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 02, 2008 | Sony KP-51HW40 51" Rear Projection...
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
