Question about Dell Dimension 4600 PC Desktop
Floppy diskette seek failure
I have a Dell Dimension E310 and when I boot the unit is gives me a black and white screen stating "Floppy Diskette Seek Failure". When I try to go into the set up screen it just reboots. What could this be?
  • 1 more comment
  • Anonymous Dec 18, 2008
    i have this same problem no floppy disk installed and i formatted and reinsatalled windows, still comes up at startup. HELP
  • Anonymous Mar 21, 2014
    It was saying floppy diskket failure I turned those settings off and now I will sometimes here 2 medium beeps and then it does 4 beeps
  • Anonymous Mar 31, 2014
    is not open just tell me no fund driver 5 and floppy diskette failure and the amcy bios no istalled
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Posted on May 19, 2008
    Champion:
  • 207 Answers
Are you using rescue disk?
Posted on Jan 14, 2008
  • Gil gil
    Gil gil Jan 14, 2008
    I think your Operating System is maybe corrupted..to check your OS, try using boot floppy disk.Insert in your floppy drive upon booting your computer.Follow instructions then type C: then type DIR,if it is displaying your files.try to reboot again your computer.
    If you don't have boot floppy disk or the same error..You have to reistall your Operating System(Windows) and go to Automatic System Recovery(F2).
    if still doesn't work..let me know.
    Scholar:
  • 146 Answers
Check the floppy drive first, if there is a floppy drive (A drive ), there could be a flopy disk already in the drive that the machine is trying to boot from...if you can get to the setup screen, the menu option "use last known good configuration" may work.
4 Suggested Answers
SOURCE: floppy diskette seek failure
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Posted on Jan 05, 2009
MGCO420
  • 11 Answers
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Posted on Jan 14, 2009
  • 68 Answers
SOURCE: "Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Posted on Jul 20, 2011
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
A used dell computer, hooked it up and black screen comes up and it says diskette 1 seek failure
Below is a list of possible causes.
Faulty or improperly inserted diskette, incorrect configuration settings in System Setup program(You might be set to boot from the floppy drive. You want to be set to boot from the hard drive), loose diskette/tape drive interface cable, or loose power cable.
If possible please rate this solution.
Aug 26, 2010 | Dell Dimension 8250 PC Desktop
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Floppy Diskette Seek Failure on boot up
Hello there:
This is a setting in the bios , so what you are going to have to do
is boot into bios and under the boot section and check to see if the floppy drive is a option that is part of the boot sequense if it is change it so that is not part of the boot sequense than go under the periphial section and check to see if it is showing up there as a removable device if so change it or disable it all together since you do not have a floppy drive ok
and this should take care of he problem
I hope that this is very helpful for you
Best regards Michael
Dec 06, 2009 | Dell Dimension 4600 PC Desktop
Jan 14, 2009 | Computers & Internet
F1 floopy diskette faliure seek faliure
Make sure it is not disabled in the boot order, there is also an option for the drive itself (Diskette Drive) that must be disabled
Jan 05, 2009 | Dell Dimension E310 PC Desktop
Jan 03, 2009 | Dell Dimension E310 PC Desktop
My sons dell e520 wont start . i get the windows starting screen then it switches to a black screen with the messag floppy diskette seek failure then the options f1 to continue or f2 to run the set up...
Have you tried to put a disk in the floppy drive when it starts up?
It probably had a disk in before last close down, and is looking for it now when you start up.
Please vote if this was helpfull :-)
Nov 29, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
6,520 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
