Wash cycle stops
Model ZWF 1221 W - machine stops at rinse cycle leaving drum with undrained water. Any suggestions would be greatly appreciated. RegUK
  • 139 Answers
Yes you have a blockage on.or you waste pump is not working..
To check for blockage undue the filter to check.
Another way is lower the waste pipe to ground leve so any water in the drum is drained away by gravity.. if water does come out then your pump is most likely faulty
hope this helps if you need any help dont hesitate to ask
Posted on Jan 15, 2008
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
Program selected ie 40c and washing machine starts. Appears to stop after the wash cycle, machine does not have water in it. The time which had moved down to around 48mins returns to start time 125mins....
It seems there is not accepting cold water on wash . The solenoid for the wash is probably open circuit. Check the solenoids with a meter for continuity. I bet you will find one open circuit. Then you can go get a new one and replace it. Might also be the pressure sensor failure, but that is not consistent with a successful rinse cycle. Make and model would have helped ..... Cheers
Mar 01, 2011 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Aeg 72630 update will not rinse during rinse cycle
if is an asko remove the top panel and check the triple valve for a faulty solenoid,also remove paddle from inside the drum with a screwdriver in the middle hole and pull toward you,and look inside the black sump hose to see if theres a plastic ball in the hose if so you need to remove it take of front panel/s to get access to the hose.also check for coins in the hoses acting like a valve.let me know and i will think of somthing else
Mar 25, 2008 | Asko W6761 Front Load Washer
Smartdrive 703 Model Washing Machine Leaving brown stains in clothing after some wash cycles. Stains are small and seem to be something coming through to the clothess from the slits in the drum holes. ...
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
Mar 14, 2008 | Washing Machines
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
Washer stops in rinse cycle
your contacts swithces for rinse cycle inside timer could be burned or bad..very model I will locate part number
Dec 15, 2007 | Washing Machines
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
