Question about iLO 3200 32 in. LCD Television
ILO-32HD wont change channels
  • 4 more comments
  • Anonymous Jan 23, 2008
    We can turn it on and get one channel but cannot get any other channel. it seems to lock in on only one we can turn it on amd off Ok Whta can we do?
  • Anonymous Jan 28, 2008
    I have the same problem. It has happened twice. The first time, it was still within its warranty period, so I returned it to Walmart. This time, the warranty has expired. Fortunately, I use a digital cable box and the tv is stuck on channel 3. Unfortunately, the sound is stuck on one volume level. All I can do is turn the tv on and off.
  • Anonymous Jan 29, 2008
    I can turn it on, but can't change channel, or move the volume. I don't know what to do.
  • NubianQueen Feb 06, 2008
    My problem is sort of the same. My remote no longer works. I'm not sure why! One day it just stop working.... so now I can't get all of my cable channels, and I can't even go into the Menu screen.
  • Anonymous May 08, 2008
    I have the ILO 32HD. It just stopped working after about 6 months of use. Now the remote doesn't respond at all. The power button will light the red standby, and any other button will light the green 'on' light, but that's it. No picture, no sound, no response to anything except the power button will turn it back off.
    If anyone knows what part is bad, i would consider buying and replacing it myself.
    If you have info... please post it here...
    Thanks...
  • karloz73 Nov 12, 2008
    I have the same problem with my TV. The tech told me that the problem is the main board. I live in Guadalajara, Mexico and I won't be able to get the main board here in Mexico, try it replacing the main board, also if somebody can help to get it, I would appreciate that...
I have the same problem too. got a number at Walmart and ask to call this number directly: Intial Tech Corporate office: 909-392-5583
Posted on May 14, 2008
6ya staff
SOURCE:
Anonymous
  • 26 Answers
SOURCE: Ilo-32HD
Check the menu to make sure it is not in a lock mode. If that is OK, it probably needs a control board. On some brands that might be called a digital or tuner board.
Posted on Jan 22, 2008
Anonymous
  • 4 Answers
SOURCE: ilo 32hd tv from InitialTech
I own an ILO TV that is still under the extended warranty. I've had it repaired twice since May 08 and it has failed again. Since it is still under warranty, I will send it back in to be repaired.... again. If I were you, I'd cut my losses and buy a new TV from any store except Walmart.
Posted on Sep 27, 2008
Anonymous
  • 4 Answers
SOURCE: ilotv 32HD
The only way that I know of to eliminate this problem is to buy a new TV. My ILO TV has been repaired twice since May 08 and it went out again for the third time. The problem starts out as an intermittent problem.... You turn the TV on, the audio is fine but there's no picture, you will be unable to change the channel or volume whether you're using the remote control or the buttons on the TV.
This TV should have been recalled. Don't throw good money after bad and don't reward the manufacturer and retailer for their bad behavior, buy your next TV from a different retailer.
Anonymous
SOURCE: Who can I call to get technical support of Ilo-32HD?
If your tv has a cable jack (screw on/in cable tv cuplink), it is then digitally abled. - Hope this helps.
Posted on Mar 16, 2009
loony2ns
  • 20 Answers
SOURCE: ilo-32HD Main PCB Assy
shopjimmy.com has a few for around $150.00, just make sure the revision #s match or eStoreGEX has listings on ebay to rebuild your existing PCB for $94.00
enter your pcb # in the eBay search i.e. MLT169B
Posted on Apr 01, 2009
I have ILO-32HD set. Wide black lines top and bottom of picture. How to remove?
Its not the set if only two channels---it does not know what channel you are on===you are describing a non problem--
May 30, 2012 | iLO 3200 32 in. LCD Television
Cracked lcd trying to buy a ilo-32 hd lcd
You do know that the LCD display will be a few dollars short of a new set ? If your still interested in it then let me know.
May 20, 2009 | iLO 3200 32 in. LCD Television
Mar 15, 2009 | iLO 3200 32 in. LCD Television
Ilo 32HD NO Channels! buzzing noise
the input setting may need changed on your tv
Dec 09, 2008 | iLO 3200 32 in. LCD Television
Ilo 32hd tv from InitialTech
Sep 19, 2008 | iLO 3200 32 in. LCD Television
Ilotv 32HD
Sep 17, 2008 | iLO 3200 32 in. LCD Television
Ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Aug 16, 2008 | iLO V27DMBX Television
Ilo-32HD
Jan 22, 2008 | iLO 3200 32 in. LCD Television
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
Cannot change channels
Hi! I have been through this situation on a 26" model of ILO LCD TV. I think the problem you have is the same, but could you clarify one thing for me? Is your model an ILO-3200, or is it an ILO-32HD? I suspect 32HD, because I know the problem exists on the 26HD models which are basically very similar in design and say manufactured by Initial Technologies on the back of the set. Does your unit list this manufacturer on the back? Let me know. Thanks!
Sep 30, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
405 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
