Machine does not start programme, it did fill but sat there in cycle did'nt advance even when reset did nothing emptied by hand did not fill again if i advance by hand just rotes back to origional position
WE bought our machine a1324 2003 APR and now it has same problem. Can't find the solution. It reset it it self when you turn it of and waited until I could open the door and then re set it. But now nothing helps. As well it started to keep loud noice when it was spining so we think it have bearing problem as well. Our machine does not start programme, it did fill but sat there in cycle did'nt advance even when reset did nothing emptied by hand did not fill again if i advance by hand just rotes back to origional positionWE bought our machine a1324 2003 APR and now it has same problem. Can't find the solution. It reset it it self when you turn it of and waited until I could open the door and then re set it. But now nothing helps. As well it started to keep loud noice when it was spining so we think it have bearing problem as well. Our machine does not start programme, it did fill but sat there in cycle did'nt advance even when reset did nothing emptied by hand did not fill again if i advance by hand just rotes back to origional position
I have the margherita 2000 AWD12 advantage and it filled but then stopped and the dial just clicks around with the light flashing until it gets to setting 8 and stops. If you reset it it does the same.
Yhis happened once before and the engineer reset it without getting his tools out - with a 'magic' sequence of button pressing that he did not reveal.
Anyone have these magic codes?I have the margherita 2000 AWD12 advantage and it filled but then stopped and the dial just clicks around with the light flashing until it gets to setting 8 and stops. If you reset it it does the same.
You can't post conmments that contain an email address.
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
According to the instruction book - it appears the machine has been stopped mid cycle then re-started. Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
H2O is the symbol for WATER and probably indicates a WATER related fault on your machine. A pressure switch is the normal way the machines 'sense' when the level is sufficient. Overfilling suggests a faulty switch, which will need to be replaced by a technician. Also, ensure that the machine drains as it should, if not, the pump filter may be blocked.
I have an Ariston Margherita AL128 and the same problem happened. After skimming through the manual, it occurred to me that it could be the pump that's causing not to drain or spin anymore. Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
hiya
to reset the dial, switch the power off, then turn the dial to a dot on the selection then switch the power on, the light should flash about 3-4 times this should be it reset.
for the machine to start doing this mid cyle though usually indicates something is wrong, i would hazard a guess at the pump filter is blocked and the mahine was trying to drain at the time it started clicking.
the best thing to do is empty the machine manually by placing the outlet hose into a bucket or large dish, once empty remove the plastic kick plate on the bottom of the machine and behind this you will find the filter.
before you unscrew the filter you will need to place some towels or old cloths on the floor as there will still be water left in the pipes, remove filter and any foreign objects (possibly coins, hair clips etc) and then screw back in. job done.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
try putting timer dial to the black dot and holding the start button until the red light flashes,then try selecting a new cycle.not sure what country you are in, aristons might be set up different in australia.hope this helps.
