Question about Maytag Legacy Top Load Washer
Top loading washer sounds real bad
My washer sounds like someone has thrown many metal ball bearings into the tub while it's agitating. It is so loud mmy neighbor can hear it. However, it still washes very good.
  • 1 more comment
  • rjknope Dec 23, 2008
    Maytag legacy top-load when agitating makes obnoxius loud noise. Washes fine.
  • bvonsosen Feb 24, 2009
    - I have a Maytag washer MAV408DAWW, S/N 10654128EE with sam problem: loud bearing? - noise below tub when spinning. Bernd (bvonsosen@juno.com)
  • bvonsosen May 11, 2010
    Did not hear from anybody, but took tub out (needed a hey-hook for removing the big springs under the tub), removed noisy tub-bearing, a Chinese 6206 RS-Z (why not 2RS - both sides rubber-sealed instead of only one?) which showed clear signs of water entry.
    While I can get a good bearing easily at any bearing dealer, I'm forced to buy the seal (the probable cause of the bearing failure) only from special washer part dealers which I will try right away.
    It is strange that seal and bearing are failing after only apx 1 year operation. I heard from local appliance service guys that this model has a bearing issue...
    Bernd
    Scholar:
  • 196 Answers
Before I can assist you I will need the model and serial number so I know what machine is being worked on.
Posted on Jan 15, 2008
If I use it everyday it's fine. If it sits a week, it makes a loud squeal during the first one or two agitation cycles. What is likely cause?
Hello. I need the model number to help you accurately. If this is a top loading unit, the problem sounds like the transmission or if it's a certain model I'm thinking of, there is an electric mode shifter that causes this symptom. What happens is this: On some top load models, there is a rubber seal located in the center of the tub, underneath the washer. If this seal should leak, water, with detergent, dribbles straight down into the electric shifter or the transmission, dissolving the high temp, long-lasting grease there. From that point, the clock is ticking until it has metal on metal operation from the bearings. Similar symptoms occur with front-loaders--the rear tub seal leaks, water/detergent gets into the bearings and causes the infamous "jet aircraft taking off or freight train in the laundry room roaring sound". In either case, it will be a MAJOR repair, requiring total disassembly/re-assembly of the washer.
Sep 07, 2015 | Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
I have a load squeaky sound on my FAV6800AWW washer. THe machine spin but when is starts agitating, the sqeaky sound can be heard.
This could be the start of Outer Tub Bearing issue.
Raise the lid of your washer and rotate the wash basket CCW as fast as you can. Does is spin down slowly to a gentle stop after several revolutions with no bearing noise?
The Service Manual for reference. Sears Parts Direct for reference.
I would by removing the Clutch Pulley and check for One-Way Roller clutches bearing wash water contamination. That will give you a feel for the integrity of the Tub Seal. See my Clutch Fix post for support.
If this is Outer Tub Bearing noise you will have to replace them along with the Tub Seal and Tranny O-ring. The Series 16 machine (I have that one also doesn’t use the upper Clutch bearing ring. That upper One-Way Roller clutches bearing is integrated into one of the Outer Tub bearings.
See this post. This guy bothered me for his statement that I left him hanging. I’m a DIY’er not a appliance tech and most AT’s won’t touch this with a 10 foot poll due to lack of knowledge. I did replace the Outer Tub bearings on a ebay win Series 10 machine. See this post for the details of that.
Don’t get too excited by any of this. 1st determine if the squeaky noise is Outer Tub bearing noise I haven’t had them fail yet but I would suspect you will hear metal against metal grinding of the ball bearings in the bearing race. There will be down time for the tear down and work. You need to determine if this is worth it for your situation. No more than a $85 to replace Outer Tub bearings tub seal tranny o-ring and buy Maytag Spinner Nut removal tool for reassembly and you extend the service life of your $1K machine.
If you want to DIY further let me know……Rich
Jun 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Loud spin cycle - leaks water
No boot on a top loader, the tub seal and bearing are gone, water leaked from the tub seal, rusted the bearing and quite possibly the milk stool and transmission. Check your warranty, the transmission may have a 5 year limited warranty, usually it will include the tub seal and bearing with the kit.
Jun 13, 2009 | Maytag Atlantis MAV9501E Top Load Washer
Loud and leaky
Tub bearing replacement on ANY Amana (Maytag) can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Maytag washers require specialized tools for removing certain components of the machine.
May 28, 2008 | Amana NAV5800A Top Load Washer
NOISE
take a flashlight and look very closely at the holes in the tub to see if there is a foreighn object in there and let me know hold your rating till we get done
Jan 15, 2008 | Frigidaire GLWS1349A Top Load Washer
Loud noise
sounds like the absence of lubrication in the transmission. could be a bad bearing on the pulley side
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
162 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
