Question about Canon PowerShot A530 Digital Camera
Canon a530 My canon a530 shutter stuck in one posistion in the middle. Have tried new batteries no luck. camera will not power up either. Can anyone out there provide a solution for me?
Power Shot A530. It came with a CD for Digital Camera Solution Disk and I put it to CD dish but nothing happening.
Of course, I have problem with downloading becuase the computer is not recoginzing the camera.
Any solution?
Somehow I did download a few times before when my internet was with dialtone. Now I have a cable.
Posted on Jan 14, 2008
Battery is stuck
I have drilled a small hole in the exposed end of the battery, taking care to not let debris from te drill bit fall into the camera. Then turn a screw into the hole and pull the battery out.
Dec 13, 2012 | Canon PowerShot A530 Digital Camera
Canon Power shot A530 repeatedly displays "change
First make sure that you are using quality batteries, and not "super heavy duty". If so, some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please see this link for more info.
Nov 25, 2010 | Canon PowerShot A530 Digital Camera
Even when i put new batteries in my canon powershot a530 it continues to say change batteries and power off
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 15, 2010 | Canon PowerShot A530 Digital Camera
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
Seems to be o.k. with sounds and menu screens,but no image of pic shows in viewer,and no image is recorded when transferred to computer
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 22, 2009 | Canon PowerShot A530 Digital Camera
My lense cover is stuck in a half-way position (Canon Power Shot A530).
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 03, 2009 | Canon PowerShot A530 Digital Camera
Change Battery
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Finally, make sure you're using rechargeable NiMH batteries rated 2500 mah or better. Digital cameras just use too much power for standard alkaline batteries.
Jan 18, 2008 | Canon PowerShot A530 Digital Camera
My flash won't work!!!
Check to make sure your camera's not on the A530 recall advisory list. Maybe the flash capacitor isn't getting enough power due to the shorting described in the advisory?:
Sep 28, 2007 | Canon PowerShot A530 Digital Camera
Problems with the battery and the flash on my canon powershot A530
Hi, On another brand/model of a digicam, a similar problem was fixed by cleaning the battery terminals/contacts. The ends of the terminals that pushes on the battery were partially corroded hence the batteries were not getting full contact. They were cleaned by scraping off the corrosion and applying a strong solvent using cotton buds. Further, they were bend a little to add more pressure to the batteries. If the above does not work, it is possible that the flash charging circuitry is defective and drawing much power than it should normally be. Try operating the digicam with the flash off. If this likewise is a "no joy", perhaps your camera would need the services of a qualified professional. Hope this be of some idea/help. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 16, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot A530 Digital Camera Logo
102 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
