Question about Flat Panel Televisions
52 inch rca tv
It comes on and then it turns off
  • 1694 Answers
SOURCE: 52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Posted on Apr 15, 2008
  • 60 Answers
SOURCE: 52 inch rca rear projection
I repaired an RCA 52" TV. I found two capacitors on the board that were bad. They were bulged on the top. This seems to be a common problem on many projection TV's. Try searching this website using the model number as your keyword.
Hope this helps,
Posted on Jul 24, 2008
SOURCE: RCA 52 inch tv will not come on and has no sound
I have the same set (D52W19B w/ TC222 chassis) with same symptoms. The set turned on a few times but I heard a sizzle. So I took off the back panel and tried to turn it on again. I heard the tube power up and then saw what was sizzling: an arc under the board about an inch behind the flyback kind of near the big metal heatsink. Any ideas? The tv was given to us so I'm not afraid to tinker with it.
Posted on Oct 13, 2008
SOURCE: 52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Posted on Nov 05, 2008
  • 11896 Answers
SOURCE: my 52 inch sanyo tv just went blank can't get it
Try unplugging it for 8 hours for reset. If this doesn't work, then fuse or power supply is faulty.
Posted on Sep 04, 2009
SOURCE: RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Posted on Sep 23, 2009
0 characters
1 Points
I turned my 52 inch RCA floor model tv on this morning. I heard a sizzling noise and now the picture is different colors
Hi if this is a rear projection TV, picture control module faulty or possible PC board damage. requires technical repair .
Jan 01, 2015 | RCA Flat Panel Televisions
When tv is turn off it wont come back on for days
The caps in the power supply needs to be replaced. Look for swollen caps if not you need an ESR meter to be extra sure.
Oct 16, 2013 | RCA D52W20 52 in. HD-Ready TV
52" rca comes on but flips thru channels and
Try here
Or Try here
Sep 26, 2011 | RCA Flat Panel Televisions
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
RCA 52" TV stopped working
It could be the problem or just a symptom of the problem. If the fuse is replaced and blows, then it's something else. Hopefully it's just the fuse. Good luck!
Mar 07, 2010 | Flat Panel Televisions
My 52 inch sanyo tv just went blank can't get it
Sep 04, 2009 | Flat Panel Televisions
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Flat Panel Televisions Logo
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
