Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
Kenmore gas grill 141-16228
I WANT TO RESTORE A GRILL THAT WAS LEFT OPEN TO THE ELEMENTS (rain). THE BURNERS ARE RUSTED ALONG WITH THE GREASE DRAIN TRAY. IWAS NOT SURE IF I SHOULD ALSO CHANGE THE BURNER BRACKET AND THE GAS COLLEECTOR BOX. I ALSO HAVE TO CHANGE THE FLAME TAMER AND COOKING GRIDS. ANYTHING ELSE YOU THINK THAT I SHOULD BE CONCERNED ABOUT? OR IS THERE A WEB SITE OTHER THAN SEARS THAT MEY HAVE THESE PARTS CHEAP?
  • bogey64 May 18, 2008
    I need to replace the bottom bracket that holds the back of the burners in place. Does anyone know if they sell these or do I need to fabricate one myself. Also the knob for the side burner will not budge. Can I buy another part for this?
  • 4 Answers
There is an Englewood, CO, retailer called Appliance Factory Parts. They sell parts for discontinued and old model gas grills.
www.appliancefactoryparts.com, at (800) 955-7075. The burner can be obtained from them or a local gas barbeque store (I found out they are interchangeable with new model grills), but the grilling and lava rock grates/grids were hard to match and I got them from Applied. I rebuilt a 1992 model Kenmore grill.
Posted on Jun 19, 2008
I would love to know the answer myself, I can't figure it out now that I have the grill half taken apart.
Posted on Apr 26, 2008
Gas burner on membersmark grill is flaring up. What can I do ?
First, check the burner for grease build up or a build up of grease in the grease pan under the burners.
Also look for rust thru or blow out on that specific burner. If it's rusted through, it will have to be replaced. Also, a build up of grease on the flame tamer will mimic a burner flare up.
Hope this helps you troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 02, 2011 | Grilling
How do we fix a gas grill that doesn't cook evenly
Usually if you're have hot and cold spots, it's the burners that need to be removed and thoroughly cleaned. In addition, cleaning the venturi valves while the burners are out, is equally important. The Venturi valves are part of each burner. You will see them near the open end of the burner (looks like 2 slots cut into each side of the burner) where it fits over the burner orifice. While the burners are out, closely inspect each one for corrosion or rust thru. If you find severe corrosion or rust thru, the burner(s) should be replaced.
Hope this helped you troubleshoot and solve the problem. Happy Grilling!!
Jul 04, 2011 | Weber 3820301 Gas Grill
I have a kenmore gas grill that has the side burner. Up until recently, it has been working great. However, now the main grill won't light when pressing the ignition button but the side burner lights...
More than likely, the electrode spark ignitors on your main burners need to be cleaned. They will get covered with grease over time. Also check the wiring from the ignitor module to each spark ignitor being sure that all wiring is firmly in place. To clean the electrode(s) ... a cotton ball dipped in alcohol will work fine.
Hope this helped you solve the problem and Happy Grilling!
Apr 09, 2011 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Yellow flame
You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
Douglas
Jun 06, 2010 | Char-Broil CharBroil Master Flame Gas...
Wont get hot fast takes for ever
It's most likely a blockage at the burners. Make sure the burners are clean of any loose rust, dirt or spider webs. Grease drippings can also clog the burners and reduce gas flow and flame.
Apr 21, 2010 | Weber Genesis Silver B Grill
My kenmore 4 burner was working fine, but after i changed gas tank, the middle two burners shoots flame under the stainless steel through the tiny holes towards the person standing infront of it...
Turn the propane tank off.
Remove the burners and clean them thoroughly of rust and spider webs, taking particular care of the throat where the orifice shoots gas into the burner. Also make sure the burner holes are free of rust. Wipe any accumulations off of the gas orifices also.
Let me know what you find.
Dec 12, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Burners light and go out on kenmore quantum
sounds like gas is not flowing enough to support all burners- if its propaine,then it has a Regulator that connects to tank. That Regulator is bad and needs to be replaced. Burners clogged or rusted is not a good thing also
Sep 29, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Sep 07, 2009 | Grilling
Glas flow will almost shut down once i turn on the second burner
hi my name is mark, let me see if i understand your problem. you light the 1st burner and get a good flame. you light the 2nd burner with the 1st burner lite and it starves both burners of gas. if this grill is a lp grill and you have propane in the tank. the regulater is the problem.
Feb 22, 2009 | Kenmore 16228 Grill
Bruner will not heat past 140 degrees, just bought a new tank
I just got done having the same problem. Disconnect the tank. Let the hose hang there for 5 or more minutes to drain any gas. Reattach the hose to the tank. Turn the knob on top of the tank SLOWLY 1/4 of a turn. Light the first burner on the left. Turn the knob on top of the tank another 1/4 turn. Light the rest of the burners from left to right. Don't open the tank valve any more than 1/2 turn altogether. When you changed tanks and hooked up the hose, the regulator in the hose cut back on the flow when the new blast of gas came through. (Its a safety feature.) So draining out the gas from the hose to reset the regulator and turning on the gas SLOWLY should give you good pressure.
Dec 26, 2007 | Kenmore 16322
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
981 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
