I can noty press fUNCTion set button
SOURCE: Can not play back pictures or use any of the function buttons
Canon Technical Support Team for starters. But if it is bust - replacement is the only course -repairs are not usually an economic proposition
SOURCE: SET button difficulties
I had the same problem...ended up getting it fixed under extended warranty. Otherwise, the problem is impossible to fix without a spare camera for swapping parts.
SOURCE: Powershot A720 Date Function
Do you want date/time stamp?
If so, you will have to be in postcard resolution.
To achieve this you will put your camera in shooting mode, hit function/set button, arrow down to bottom left corner where you will see L, M, S and postcard modes. Select the one that looks like a postcard.
Hit function/set to get out of there. Now hit menu and go to setup menu (tools) and arrow down to date stamp and make sure it's on date and time.
images shot in this resolution will look good as 4x6 prints, but should not be printed any larger or they will look pixelated, not good quality for larger prints.
Either that or you can add date and time in the Zoombrowser program that came with your camera should you need larger prints with date/time stamp.
I hope this helps!
SOURCE: PS A85 takes pictures fine, but I can't use menu,
firmware update
go to canon.com and search for your camera then download the firmware update and install it while the cam is connected via USB
SOURCE: Lost all button functionality except power and shutter
There is a secondary battery I suppose for memory retension. It is housed where the other batteries and memory card are, the battery is a CR1220. I replaced that battery and things are working well again.
